Last questions of engine build
  • jordan
  • jordan's Avatar Topic Author
16 Nov 2007 16:55
#181389
Ok, head is back from machine shop, assembled and placed over the wiseco pistons on my 81 kz750. By the way the head is a gpz head, along with the cams. I dont have buckets to cover the valve spring retainers for the gpz head, but figured i would use the ones from the kz750 head. They dont seem to fit. I am assuming the gpz buckets are slightly bigger, is this correct?
Next, the cam chain seems to be very tight, and I cannot spread both cams to their spots. Even if I accomplish this the cam chain would be VERY tight, isnt there supposed to be a little slack in the chain?
Also, I have heard that plugging the holes for the Emmission system deal that sits on top of the valve cover will make it unusable. The head is already installed, but can I put a rubber stopper/plug like device in the hole to solve this problem?
Lastly, I will need to time the motor. Is their a trick to doing this? Are any special tools required. I will soon have access to a service manual for this bike and I assume it will give directions for this procedure. Would the timing be the same as recommended in the manual even with the gpz head/cams?
Thanks alot, KZrider has been alot of help throughout this build
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • themachine
  • themachine's Avatar
Re: Last questions of engine build
16 Nov 2007 17:17
#181390
need divfferent retainers, take the tensioner off, and yes it has the info you need.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • jordan
17 Nov 2007 12:45
#181483
Different retainers? Are you referring to the bucket like objects that cover each valvespring?
The cam chain tensioner is already off, any other ideas?
Help would be GREATLY appreciated, I would like to get it all together soon.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • Bluemeanie
  • Bluemeanie's Avatar
17 Nov 2007 13:01
#181487
If your talking about the 2 plates on top of the valve cover, just run a hose from one side to the other! Everyone here has done it, will actually run better with emissons off, no more back fire thru the exhaust!
  • The Milkman
  • The Milkman's Avatar
17 Nov 2007 14:16
#181491
By any chance is the head you are putting on taller than the old one so you need a longer chain? If not that, is the chain on the lower spocket or binding somewhere so you don't have it pulled up all of the way.
  • jordan
17 Nov 2007 15:44
#181509
Figured out cam chain issue. I pulled off the ignition cover and turned the motor over a little. This seemed to free up more chain, and both cams fit nicely now.
Anybody know about my retainer question yet???
The cams are just snugged down for now, until I can figure out about the buckets, or retainers if these are the same thing. Then, I noticed numbers and arrows on the deals that hold the cams down. Does anybody have a picture of the order these go on.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • The Milkman
17 Nov 2007 18:55
#181535
The exhaust caps are numbered 1 to 4 left to right,, the intake are 5 to 8 left to right,,, all arrows point to the front.
Left to right is still counting cylinder 1 on the left.
Post edited by: The Milkman, at: 2007/11/17 21:56
  • jordan
17 Nov 2007 18:57
#181536
Thanks alot Milkman, you've been alot of help
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • jordan
17 Nov 2007 18:58
#181537
This may sound dumb, but is there a distinguishing mark that seperates the exhaust cam from the intake cam. I havent looked too closely yet, but they look the same.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • The Milkman
17 Nov 2007 19:47
#181542
Somewhere I read that the exhaust cam is acutally darker because it is hardened more. And if you look at the arrows that line up with the head you can see them from the right hand side of the engine. Hope this helps.
Post edited by: The Milkman, at: 2007/11/17 22:52
  • kzdev1360
  • kzdev1360's Avatar
18 Nov 2007 17:26
#181625
make sure when you install the cams that the 1 and 4 pistons are at TDC, you can do this by looking at the advancer plate and turning the engine with a 13mm wrench to where the "T" mark by "1-4" is perfectly lined up with the marking. A retainer is what holds the valve and the spring together. It is the round flat thing that is ontop of the valve spring, that the valve stem pokes through.
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
  • The Milkman
18 Nov 2007 19:48
#181657
Don't turn the engine with a 13mm wrench, you could break the head off it, use a 17mm on the bigger inner nut!!!!
