z650 clutch question
- Dave Sloan
16 Nov 2007 16:26
I have an APE clutch kit for my kz650 (including springs) that I am going to be fitting shortly, I have read that the APE springs make for a heavy clutch lever.
How many guys are using the heavy duty APE kit and are the heavy duty springs ok for a street bike?
:laugh: :laugh:
:laugh: :laugh:
Z650B2 - Injected
- rstnick
Re: z650 clutch question
16 Nov 2007 18:25
I've got a Cir Cycle heavy duty clutch in my bike and I switched the springs back to stock last Winter. After two years of a heavy clutch, I had to make it easier. I'd have to rest on longer rides because my clutch hand would get too sore. Some rides I'd have to stop two or three times to rest my hand.
Make sure your cable is smooth as well, as this adds to the problem. I ended up putting a new cable on as well because I could feel the drag on the old cable.
Post edited by: rstnick, at: 2007/11/16 21:27
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- flht1997
16 Nov 2007 18:44
i have a set of "heavy duty" springs in my 650, not APE brand so i cannot comment on those specifically, but mine suck. regret that installation.
clutch pull is way too stiff, and i never had a problem with the stock stuff, i just did not think these would be this bad.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- madderkaw
19 Nov 2007 02:48
I recently installed an APE clutch kit on my 80 650. I also used the APE roller bearing push plate. I have not found that big of a difference in cluth pull. I don't know if it's the clutch alone or combined with the other mods I did, but it wheelies much easier now.
