Recognize Oil Pan Debris?
- Norseman
15 Nov 2007 07:39
I finally got the engine out of the frame, fabbed mounting hardware, and up on the stand:
When I removed the oil pan, I found this:
The washer was undamaged, so I have to assume "no foul", but how it got there is anyone's guess...
What bothers me a little is the redish-orange hard plastic pieces. The outer and inner edges have a slight curve, as well as thickness diminishes from outer edge to inner.
Do any of you recognize what these pieces may be from? The pieces appear to be a material similar to "bakelite" - what old phones were made of.
Post edited by: Norseman, at: 2007/11/15 10:41
Post edited by: Norseman, at: 2007/11/15 10:42
Post edited by: Norseman, at: 2007/11/15 10:47
- Bluemeanie
Re: Recognize Oil Pan Debris?
15 Nov 2007 07:45
The far left pieces almost look like clutch material?
- mariozappa
15 Nov 2007 07:45
I would say the black hard plastic is part of the old cam chain rubbers.
22mm OD washer, perhaps the washer that goes on the head where you tighten down the head nuts.
Everything else.....I dunno.
:S
:S
1977 KZ650C1
and the KZ650/KZ750 Conversion
- OKC_Kent
15 Nov 2007 11:21
The different rubber and orange plastic stuff is probably the cam chain adjuster parts?
And that's the lucky washer they toss into every 1000 engine...:whistle:
By the way, I really like your engine stand.
Post edited by: OKC_Kent, at: 2007/11/15 14:23
Cashion, OK
78 KZ650 B2 85,000+ miles
- coppertales
15 Nov 2007 11:23
The washer looks like a head nut washer. The aluminum flakes look like what I had in my engine. The clutch pushrod had rubbed down where it comes through the case on the left side. Eventually the pushrod wore through and broke. Might want to pull it out and see. If it is not worn too badly, just reverse it. The hard rubber is from a cam chain guide getting hard and breaking up. The gravel is from the road, how that got in there, who knows......chris3
Forgot the red plastic. Looks like the bonding material holding the magnets to the rotor.....chris3
Post edited by: coppertales, at: 2007/11/15 14:24
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- dannyg40
15 Nov 2007 11:28
coppertales wrote:
Thats exactly what it is. Just changed my stator and found a few tiny pieces of the same red stuff from the rotor missing.
Forgot the red plastic. Looks like the bonding material holding the magnets to the rotor.....chris3<br><br>Post edited by: coppertales, at: 2007/11/15 14:24
- Norseman
15 Nov 2007 14:42
Thanks for all the responses, Guys! That redish material just had me stumped - didn't recognize it and was bothered by the fact that I couldn't identify it. I didn't even think about the bonding material holding magnets to rotor.
If it is that, there's more than just a few tiny pieces. When I place them together, it's almost 2.5 inches worth. Do I have a significant problem here? Where do I look for missing materials? The stator looks fine, but it may have been replaced in the past, I simply don't know. Appreciate some advice or direction.
Coopertales: I did as you suggested with the clutch pushrod - it looks pretty worn, and I will replace it as part of the build - thanks for heads-up!
OKC_Kent - the engine stand is actually a cool story. I stopped by Murray Auto to check on some wiring for my harness. I mentioned to the manager that I was looking for a bike lift and an engine stand. He asked me if I had a minute and took me out back where they were looking to get rid of a discontinued Chevy small-block on a stand which was a display. He said if I helped him get the engine block off, he'd let me have the stand for $25. Needless to say - I helped him and left with the AC Delco engine stand. Once in a great while one gets blessed, eh?
- KaZooCruiser
15 Nov 2007 15:16
My guess on the washer is that somehow it got left behind during an oil change. Maybe it is the one that is supposed to be against the filter to keep the spring from contacting it.
Course, my bike might be a different setup than yours. And I don't really know what size the washer is.
:blink:
But seeing what was found in your pan, it might be a relly good idea to start over with a new oil pump.
:blink:
- Norseman
15 Nov 2007 16:21
I forgot to mention - the redish/orangy pieces must have some trace amount of ferrous metal content because I can pick the pieces up with a magnet.
Okay, I checked the parts diagram and that washer on the 1981 KZ1000 should be 20.5x30x1mm, and the one recovered from oil pan is 10x21x1.5mm. Got me thinking though, KaZooCruiser, and checked my oil filter. Lo and behold, that washer between the spring and filter is missing.
I couldn't find any oil pumps on Z1Enterprises, what would a new pump run (if anyone has had occasion to buy one?). Here's my reasoning: I'm putting some money (and alot of labor) into the bike this winter, such as honing cylinders with new rings and all gaskets, powder coating frame, painting tank/covers (not rattle can), new R&R, etc. If all that is done and the oil pump fails...
What'da think?
Post edited by: Norseman, at: 2007/11/15 19:27
What'da think?
- CoreyClough
- GPz550 Addiction
16 Nov 2007 05:07
I had similar aluminum flakes in the oil pan on my 44,000 mile motor after hearing tapping noises above idle and it looked like this:
Turned out to be #3 cylinder rod knock that's common on 550 motors with high mileage, from what I've heard.
Yes the sludge/oil is the water that got in there after the bike was sitting outside. The noise was there before it sat in the weather, so it didn't create the problem
The original cam chain sliders were in great condition.
Removing the oil pan is something I recommend everyone do at some point after buying a bike. You gosta know the bikes maintainence history.
Lucky Washer? That's funny!!! :laugh:
Post edited by: CoreyClough, at: 2007/11/16 09:15
'85 GPz550(ZX550-A2)
- patmann
16 Nov 2007 08:35
OKC_Kent wrote:
Well there's a DAMN lucky Yamaha out there someplace.
I had a buddy ( now dead ) who's girlfreinds ex boyfriend dumped a handfull of change and some nuts bolts and washers down his oil fill hole :pinch: :ohmy: :S :dry: :blink:
Seems the ex boyfriend was afraid to do anything to my buddy face to face over the girl, but decided this would mess him up:pinch:
At least that was the story. My buddy sold the bike about a year later with NO problems that we knew of.
Anybody have a 650 Yamaha with strange problems in the bottom end???
:whistle:
Pat
.<br><br>Post edited by: OKC_Kent, at: 2007/11/15 14:23
:whistle:
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
