WD-40 in cylinders for winter storage?
- old650
14 Nov 2007 14:05 #181064
by old650
WD-40 in cylinders for winter storage? was created by old650
Oooops...looks like I forgot to pour a little fresh oil in the cylinders like I do every fall, for winter storage. Now I have to fiddle fart around, uncover the bike and have at er'. I was thinking that spraying WD-40 into the cylinders would be a lot quicker to do than pouring in some oil. Sound good or do you see a problem with this application? The bike is stored outside and it's getting on the nippy side now.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
14 Nov 2007 14:36 #181068
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic WD-40 in cylinders for winter storage?
I know from my time in paintball that wd-40 will degrade o-rings over time; it will often make them swell and soften; in paintball the end result was a marker (gun) that would leak air.
I wd-40 is a lubricant and a solvent.
I would use the oil, how much longer would it take?
1977 kz650 c1
- Makarth
- Thank you received: 1
14 Nov 2007 15:18 #181080
by Makarth
Replied by Makarth on topic WD-40 in cylinders for winter storage?
wd-40 will evaporate over time and it sucks for rust prevention as i learned in my machine shop class.
lazy bum :woohoo:
lazy bum :woohoo:
- BSKZ650
- Thank you received: 14
14 Nov 2007 16:45 #181085
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic WD-40 in cylinders for winter storage?
NO WD 40, the stuff was made to displace water, not as a oil, if you are going to take the time to pull the cover then take the time to winterize it the right way
- rstnick
- Thank you received: 377
14 Nov 2007 16:47 #181086
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic WD-40 in cylinders for winter storage?
Oil is better.
Also try to kick the starter over a bit every once in a while to move the cylinders to a different spot.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- kawsakiman
- Thank you received: 6
14 Nov 2007 17:52 #181098
by kawsakiman
Replied by kawsakiman on topic WD-40 in cylinders for winter storage?
go get yourself a turkey baster and pull the plugs.
why the hell are you leaving the kz outside anyway?
we all know they like being in the dining room so you can kiss them goodnight.
shame on you!
:laugh:
:sick: :ohmy: :woohoo: :evil: :blush: :side: :woohoo: :dry:
shame on you!
:laugh:
- coppertales
15 Nov 2007 11:47 #181201
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic WD-40 in cylinders for winter storage?
No, do not use WD40. As posted above, use engine oil. I use LPS2. It is a milspec lube and rust preventative. However, I live in Texas where I ride all year around.......When I lived up north, I just put the bike in the garage and never had a problem......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- JMKZHI
- Thank you received: 48
15 Nov 2007 14:13 - 03 Dec 2008 07:05 #181215
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 03 Dec 2008 07:05 by JMKZHI.
- old650
17 Nov 2007 01:28 #181423
by old650
Replied by old650 on topic WD-40 in cylinders for winter storage?
Some responses that brought a smile.:laugh: Ok, ok, I got off my lazy hoop, pulled the plugs and put some fresh oil in. Actually I did use a turkey baster this year. And yes every year I oil the cylinders and cycle through several times with the kick starter. Thanks for the WD-40 info, I wasn't sure.
- jaguar
17 Nov 2007 06:11 #181436
by jaguar
Replied by jaguar on topic WD-40 in cylinders for winter storage?
Marvel mistery oil is your huckelberry.
Thats what Dynamo Hum would use!
Post edited by: jaguar, at: 2007/11/17 09:12
