5 second rule
  • brianpclarke
  • brianpclarke's Avatar Topic Author
5 second rule
10 Nov 2007 09:24
#180467
sooo.... wondering if you guys could help me out... I am rebuilding a 1978 kz650 which hasnt been started due to neglect in about 5 years (bought it from an elderly man)and am switching parts with my previous daily rider... a 1978 kz650. After countless bloody knuckles, swearing at the bike, etc..... I got her running!..... for about 5 seconds. Since I have tried everything I can think of... messed with the air screws on the carb (which was switched over from my previous bike) checked this and that... but it will stubbornly start after a couple kick starts... struggle to 4000 rpms and then die immediately. so maybe something electrical? I cant think anymore so any advcice would be greatly appreciated.
-Brian
1977 KZ650C
1976 Kz900 LTD
  • BoZ650
  • BoZ650's Avatar
  • 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
Re: 5 second rule
10 Nov 2007 10:40
#180477
Is it new gas?Have you cleaned the points?Checked for spark?Checked compression?Is a battery installed?
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: 5 second rule
10 Nov 2007 11:11
#180480
Does the gas flow out of the tank? If not try it with the gas cap open. If gas flows, disregard the first comment I made.
'85 GPz550(ZX550-A2)
  • themachine
  • themachine's Avatar
Re: 5 second rule
11 Nov 2007 15:39
#180591
vaccume leak?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • kzdev1360
  • kzdev1360's Avatar
Re: 5 second rule
12 Nov 2007 07:44
#180656
Timing? Sounds like it is possibly not firing on all four cylinders? My coils sometime after i touch any of the wiring like to mess up and it reluctantly starts but sounds almost like a harley and that is my clue to a misfire.
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
Re: 5 second rule
12 Nov 2007 08:09
#180664
brianpclarke wrote:
...got her running!..... for about 5 seconds.... will stubbornly start after a couple kick starts... struggle to 4000 rpms and then die immediately....
Thinking possibly a fuel supply problem, but some fuel gradually making its way into the float bowl to allow running for a few seconds until the float bowl empties again.
With engine off, could experiment by opening float bowl drains and then turning on petcock and seeing whether fuel continously flows out the float bowl drain holes. If not, suspect low fuel in tank OR crud inside tank suspended around and clogging petcock filter inside tank OR petcock clogged OR petcock screen clogged OR fuel line clogged OR in-line fuel filter clogged OR fuel tank cap vent clogged. :)
Post edited by: Patton, at: 2007/11/12 11:10
  • brianpclarke
Re: 5 second rule
12 Nov 2007 21:46
#180798
Awesome! thanks for all the feedback! Tomorrow I am going to basically try all of these and nail it down or else I am going to go insane if I have to pull the jeep up to the gas station another time this week.... but what would a vacuum leak be? and how would i check this out?
-Brian
1977 KZ650C
1976 Kz900 LTD
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: 5 second rule
13 Nov 2007 03:14
#180815
The vacum leak would be anything to do with the rubber parts. Check fo cracks on the intake boots and make sure there are no open vacum fittings on top of the carbs.
Also try some light oil in the cylinders. If the bike has been sitting for a lonfg time the rings could be stuck. Roy
  • brianpclarke
Re: 5 second rule
13 Nov 2007 12:36
#180870
Post edited by: brianpclarke, at: 2007/11/13 17:57
-Brian
1977 KZ650C
1976 Kz900 LTD
  • brianpclarke
Re: 5 second rule
13 Nov 2007 12:38
#180871
oh.... sorry guys... the problem was a mixture between a weak spark and bad gas.... problem solved and my itch for Kawasaki riding gets worse....
-Brian
1977 KZ650C
1976 Kz900 LTD
