is my head junk?
- School Teacher
Post edited by: School Teacher, at: 2007/11/07 13:30
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- School Teacher
1980 kz1000G1
- kawsakiman
- Thank you received: 6
i'm sure ape/kzzone can also take care of you.
click on the link on the right of this page,
the essentials, and ask them.
kzzone.com/resources/sitewides/header.jpg
fastbygast.com/
Post edited by: kawsakiman, at: 2007/11/07 16:06
- nads.com
- Thank you received: 20
- PLUMMEN
- Thank you received: 104
- School Teacher
1980 kz1000G1
- School Teacher
I can't see it clear enough but it looks like the bad part is inside the combustion seal. If it is, u can use the head no problem just smooth the rough edge around the inside with emery cloth. Let us know what cams u have, I aquired a set the same way as u and they are pretty good cams! Measure the lift from nose to heel and that should be all u need to determine who made them.
well the nose to heel is 1.507 inches to 1.510 inches depending on how well i measured
they have k259
i-5 and c-1 cast into them along with USA and on the end they have khl-1 stamped in the end
1980 kz1000G1
- nads.com
Post edited by: nads.com, at: 2007/11/08 03:13
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- nads.com
Post edited by: nads.com, at: 2007/11/08 06:47
Post edited by: nads.com, at: 2007/11/08 06:49
- Lorcan
- Speed Loony
- Thank you received: 59
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- larrycavan
- Visitor
Anything with compression - no way. Get it fixed or get another head.
"Only a farmer can start with shit and end up with something"
