Putting '82 KZ1000 CSR Cams on '78 B2?
  • Skyman
  • Skyman's Avatar Topic Author
06 Nov 2007 12:58
#179889
In the process of rebuilding my '82 CSR, I purchased a replacement head assembly that came complete with a set of stock CSR cams. So now I have two sets of stock cams for this bike.
Today, I just happened to be browsing E-Bay, and I saw a listing for CSR cams. I was thinking about selling my extra set, so I was going to watch it to see what it went for. But in reading the description this guy had for the cams, he wrote that you could put these cams onto a '73-80 model, just need to get a set of APE conversion sprockets. He wrote that these cams give you 0.020" more lift, so better performance.
So I got to thinking about the possibility of putting these cams onto my '78.
So that brings up a couple questions.
1. Do these cams truly have 0.020" greater lift?
2. Would that make a noticeable performance difference?
3. Can I just take the sprockets off of my stock B2 cams and bolt them onto the CSR cams?
4. Anything else I should be aware of with this operation?
Thanks.
Post edited by: Skyman, at: 2007/11/06 16:02
West Linn, OR
  • Skyman
Re: Putting KZ1000 CSR Cams on '78 B2?
06 Nov 2007 13:00
#179890
Here's the link to the EBay ad I referenced: tinyurl.com/2u6z6r
West Linn, OR
  • Skyman
07 Nov 2007 09:37
#179976
Anyone?
Thanks.
West Linn, OR
  • themachine
  • themachine's Avatar
08 Nov 2007 03:01
#180083
you'll lose powah, as they dont have as much duration as kz cams (i think) the 82 csr/ltd's made 92 hp wheras the 82kz standerd made 102hp with different cams and carbs.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • otakar
  • otakar's Avatar
08 Nov 2007 06:24
#180099
I think Skyman is talking for his 78. Check the lift for comparrison with a mike or calliper first before you go threw all the trouble.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Skyman
08 Nov 2007 08:15
#180114
Yes, I am talking about possibly putting '82 M2 (CSR) cams on my '78 B2.
I can mic them, no problem. I think I understand how to measure for lift--that's just a measurement of the total height of the lobe, right?
How does one determine the duration? Do I need to mount them and use a degree wheel for that?
Assuming the information from that EBay seller is correct--that these cams do give an extra 0.020" of lift, what would that potentially do for me. Is it worth the effort?
Sorry if these are stupid questions, this is uncharted territory for me.
West Linn, OR
  • otakar
  • otakar's Avatar
08 Nov 2007 08:58
#180119
Twenty Thau is quite a bit. Even if the duration is less than the orryginal, which I doubt, it would only give you a wider powerband.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • School Teacher
  • School Teacher's Avatar
07 Dec 2007 11:31
#184083
can you just swap the stock sprockets?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • otakar
  • otakar's Avatar
07 Dec 2007 12:34
#184098
I believe that the CSR cams already come with the two bolt sprockets vice the older 3 bolt. You must get a conversion sprocket or make one. (TWO)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
