GPZ cams in 78 KZ 650????????
- odl666
05 Nov 2007 13:57
I have rebuilt the head on my kz 650, polish and ported as well as being milled 25 thousanths, I was wondering if i use the kz 650 cam sprockets will i still need to degree the cams? or will i be able to install them how the manual tells me. I am using a veserah head gasket and a ape chain tensor. Also what is my new redline gonna be for my 650.
Thanks
Thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- BSKZ650
Re: GPZ cams in 78 KZ 650????????
05 Nov 2007 16:19
since you have done all that work, why not go ahead and degree the cams in, you will like it
77 ltd1000, current rider
76 kz900, just waiting
- steell
05 Nov 2007 16:22
You don't "have" to degree the cams, but the chances of the timing being accurate are slim to none
Redline is determined by a number of factors, it's impossible for me to tell you at what rpm your motor is going to self destruct.
Assuming you used new GPz750 or aftermarket springs, then I'd guess 10.5k would be safe, but I can't guarantee anything.
- odl666
06 Nov 2007 09:44
So does anyone know where i can learn how to degree my cams? Thanks also anyone know how i could due the math for my cams. Thanks
1979 gs750e
1979 gs750e
