Wiseco 810cc kit
  • Jimbo750
  • Jimbo750's Avatar Topic Author
Wiseco 810cc kit
03 Nov 2007 03:06
#179405
I am interested in getting a kit for a 750 engine i am building but i have herd of problems with these kits burning alot of oil, Has anyone any experiance with this??
Thanks Jim
  • steell
  • steell's Avatar
Re: Wiseco 810cc kit
03 Nov 2007 03:58
#179409
With the Wiseco 1105 kit for the J motor, I have heard of it having problems (sleeves are really thin after boring that far), but I have not heard of a similar problem with the 810 kits, and there are a number of members that have them (working on one myself).
Of course improper assembly will make any motor burn oil.
  • otakar
  • otakar's Avatar
03 Nov 2007 05:09
#179413
I Heard the same thing quite a few years ago on the early kits. Wisco useg 1.8mm rings they did not create enough preassure on the cylinder wall and therefore did not scrape the oil propperly. Wisco got smart shortly after and replaced the rings with 1mm rings and that created more surface tension due to the smaller contact area. I have a RC Engineering 1105 kit in one of my Z1Rs in the stock sleaves. I installed it back in 1979 and never had a single problem. I was told the same thing about the 1105/1103 kits years ago;)
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
03 Nov 2007 10:07
#179436
As Otakar says, the early kits had problems, but they are a well sorted kit now.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • Kiwiz
  • Kiwiz's Avatar
03 Nov 2007 16:37
#179475
Hi,
I installed a 1015cc Wiseco on my J as it represented a cheaper rebuild option than stock and I have not had any oil burning problems at all.
  • APE Jay
  • APE Jay's Avatar
03 Nov 2007 23:13
#179518
If the block is bored and hon ed correctly you will have no problem.
Jay
  • Jimbo750
04 Nov 2007 22:59
#179636
Thanks guys, sounds like its gona get a kit then. Jim
