85 900 ninja plug socket size
- jaguar
02 Nov 2007 16:39
Howdy, What size socket do I need to buy to remove the spark plug?! I tried all mine and then went to auto zone and we took what was suspose to fit my bike and got a socket for it and IT doesnt fit either! Was I spose to get a left handed socket! Joe
- roy-b-boy-b
Re: 85 900 ninja plug socket size
02 Nov 2007 18:15
I think it is a 17 mm. I do know you have to use a 3/8 drive socket. Riy
- jaguar
05 Nov 2007 05:39
Hey Riy, I believe thats what I bought at the zone. But its going to take a real thin wall socket to do the trick. Just wanted to take them out so I could crank the motor over with the starter and check the alignment of the trannie gears before I put it back in the frame. I actually figured out the alignment last night and its shifting real smooth by just turning the crank with a wrench. But, I still want one to fit! Off to the kaw dealer. Joe
- The Gringo
- ¡Usted no necesita otra motocicleta!
05 Nov 2007 06:01
It's an 18 mm.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- jaguar
06 Nov 2007 05:24
Ok, cool, I will try that one next. Thanks, Joe
- roy-b-boy-b
06 Nov 2007 15:27
18mm and a lot smaller than the 18mm i had in my set. I went to O'Rilies with my old 3/8 socket and found one that worked. Roy
- jaguar
06 Nov 2007 19:18
You mean smaller as in a thinner sidewall? That seems to be the sticking point. Joe
- nads.com
07 Nov 2007 01:08
Take an 18mm socket to a bench grinder and thin the walls if u need to.
- roy-b-boy-b
07 Nov 2007 03:02
Thinner Walls.Roy
