KX dirt-bike question
  • Sandy
  • Topic Author
  • Fly High,Tony
14 Jan 2006 18:18 #17931 by Sandy
KX dirt-bike question was created by Sandy
Not KZ,but it IS Kawi...
My Son is looking at a 92 KX250...
What kind of compression do We want to see when We DO a compression test,when We take a closer look at it?
What is the minimum amount,before a Person should walk away from it?
The bike DOES need some work,and a few parts,but the price IS in Our range.
Thanks GangB)
1977 KZ1000 A-1
  • wireman
14 Jan 2006 18:42 #17937 by wireman
Replied by wireman on topic KX dirt-bike question
if it runs take it for a spin ,youll know pretty fast if shes worn out!if it doesnt run bid very low or run like hell!bwaha goodluck,happy wrenching!
  • Aloha Mr Hand Z1R
14 Jan 2006 19:19 #17945 by Aloha Mr Hand Z1R
Replied by Aloha Mr Hand Z1R on topic KX dirt-bike question
not sure what the compression should be, but as long as it starts up and runs, it's probably worth it if it's a good price. top end rebuilds on dirt bikes are almost routine maintainence and pretty easy. If you can, take off the left side engine cover and grab the mag and wiggle it up and down to see if the crank has a lot of play. If you get into a bottom end rebuild it's a lot more time and $$... I just rode my 14 yr old cousins 97 KX80 a couple weeks ago.. woo-hoo!! It's been a long time since I've ridden a fast dirt bike... what a blast and it was only an 80!
15 Jan 2006 19:26 #18082 by CombatTalon2
Replied by CombatTalon2 on topic KX dirt-bike question
I agree, if it runs its probably fine. A bike that age will probably need a rebuild no matter what. I would suggest throwing a new piston and rings in it just so you know the top end is fresh. Two strokes are really easy and cheap to do top ends on. I have a Yamaha Banshee, 2 cyl, 2 stroke. yeeehaaaaa....
Post edited by: Combattalon2, at: 2006/01/15 22:27
15 Jan 2006 20:33 #18089 by xr350guy
Replied by xr350guy on topic KX dirt-bike question
yea, i totaly agree, thro a piston and a set of rings in er' and it will probly run like new.
17 Jan 2006 01:58 #18218 by tullymars
Replied by tullymars on topic KX dirt-bike question
100 pounds is servicable...minimum
17 Jan 2006 06:24 #18233 by DasTeufel
Replied by DasTeufel on topic KX dirt-bike question
wow...100 psi minimum? That's pretty dang low!
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
