Engine Swap -1981 CSR 1000 motor into 73-80 Frame
  • Oldhemi
  • Oldhemi's Avatar Topic Author
01 Nov 2007 15:00
#179176
New to form - I posted in the newbie forum already with this basic question. I know double posts are a bad thing but i know the new guy intos don't get as much reads.
Here is the deal:
I have a '70's Amen chopper frame built for '70's 900/1000's.
I have a line on a 1981 CSR that I am looking at in a couple of days. My research indicates that my aftermarket frame was built in the 70's. I have learned that the '81 csr motor was changed a lot and that it will not be a straight drop-in.
Has anybody here swapped a "J" motor into a 73-80 frame or vice-versa. Please ignore that it is an aftermarket frame that I am dealing with.
Hope to hear from someone that has this knowledge.
  • themachine
  • themachine's Avatar
Re: Engine Swap -1981 CSR 1000 motor into 73-80 Frame
02 Nov 2007 03:13
#179241
does that amen chopper frame happen to have airbrush artwork all over it and one of the murals happens to be of a cow?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • StreetfighterKz
  • StreetfighterKz's Avatar
02 Nov 2007 04:18
#179245
Welcome. Yes there are some people who have swapped to the later J-model engines here. Try using the search function and you'll be able to find all the answer I can't give you since I've never done it.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Oldhemi
02 Nov 2007 08:44
#179285
Thx for some responses.
I have been through search for hours and have not found anything yet.
I even emailed oldmankaw and got a decent responce even though he has never done it. His major concern was if there was enough room for the valve/cam covers. Did not know that was so different, so I have learned some valuable info so far.
The frame has never been used. No mural on the frame, let alone "factory" primer left. Would think a frame would have pretty small mural,no?
BTW, the CSR that I am hopefully picking up tomorrow has been yakked about here on the forum. It was on Craigslist and then ebay with bad bidder. Its up in
Cut and Shoot.
Yeah, thats a real name of a real town here in Texas.
AND, I might not go this route if the CSR is in good shape to leave complete in stock condition for me or somebody else. I have no plans of using more than the motor in any case. Maybe the whole front end depending on bearing availability for Honda/Kawi swap.
I recognize rarity, desireability and value. I do have a very nice Honda 750 Sandcast!
  • StreetfighterKz
02 Nov 2007 10:15
#179300
Go take a look at the Dragbike.com forums. I definitely know its been discussed before on there but I couldn't find it. There was a guy that even made mounts so he could switch back and forth between early and late model Kz engines. He showed some good pics.
Good luck.
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Nov 2007 11:02
#179306
Cut and Shoot.
There used to be a quality BBQ place in Cut-and-Shoot...used to drive there a number of years ago...check the classifieds...there is a 1977 frame with a J motor in it for sale right now...so it can be done.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Oldhemi
02 Nov 2007 11:11
#179309
BIG THANKS Doug. Took me just a few minutes too find the post including pics of what he did. Way more than I can do at this time.
BUT, my Amen frame has some advantages that he did not with the early frame. It has removable rear mounts and 1 forward mount on the frame. Might just have to do 1 more forward mount. There is hope yet.
Here is a link if anybody cares.
[/url] forums.dragbike.com/forum_posts.asp?TID=6454&KW=kawasaki+++ [/url]
Post edited by: Oldhemi, at: 2007/11/02 14:13
Thanks Mike. I'm assumeing that you mean KZrider's classified.
I'll get this darn link'ing system figured out yet! Might take a few more edits unless someone offers to help.
Post edited by: Oldhemi, at: 2007/11/02 14:15
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Nov 2007 11:52
#179314
Oldhemi wrote:
Thanks Mike. I'm assuming that you mean KZrider's classified.
Yes, the seller is Paladin13...he sent me a photo...if you are interested in seeing it, I'll send you the link.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Oldhemi
02 Nov 2007 18:12
#179370
Hey Mike, If you would not mind, I would like to see the foto. I looked at the ad and said "self, don't get carried away here". I kind of wish that I knew a bit more about the differences in the motors before I commited to the CSR. But, who knows maybe I'll have a couple of the green teams version of the UJM to add to the collection. Should be picking it up tomorrow.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
05 Nov 2007 02:44
#179649
Oldhemi...check your PM:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Oldhemi
05 Nov 2007 13:42
#179743
Hey Guyzzz. I am closing this post out. I want to thank everybody for their help. I understand what I need to do if i decide to do this. B)
