Standard Piston?
  • tellietubbie
  • tellietubbie's Avatar Topic Author
Standard Piston?
14 Jan 2006 17:22
#17915
Sorry Wireman, I meant to ask if anyone had experience of trimming the end gaps of first oversize piston rings to fit a standard piston, my European Z500/4 isn't supported anymore by Kawasaki and I can't find standard rings:(
Post edited by: tellietubbie, at: 2006/01/14 22:44
  • wireman
  • wireman's Avatar
Re: Standard Piston?
14 Jan 2006 19:35
#17947
how about a standard post i cant see anything: :whistle:
  • steell
  • steell's Avatar
14 Jan 2006 23:49
#17960
I don't think that would be a good idea, but it might work in a pinch. I think you will have increased ring tension causing increased drag on the cylinder wall and possibly increased wear, I'm also not sure how round the rings are going to be after you compress them that far.
I have seen stranger things done though.
Any possibilty of getting a 550 jug and pistons and just making it into a 550?
Or getting oversize pistons to go with the rings?
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
15 Jan 2006 04:50
#17963
If you can get a part number for the standard rings, I can check to see if Kawasaki in Japan still has any.
I don't have any parts reference for this bike.
  • tellietubbie
15 Jan 2006 05:06
#17965
Thanx for that Steell, everyone does the 500 to 550 thing and I,m trying to restore it to origional,plus,after new jugs,pistons, re jetting,:blink: I'd have a bike I didn't want :( Jeff sent a msg about contacting Kawa Japan so I 'll give that a go.Thanks again for your i/p. Pete
  • tellietubbie
15 Jan 2006 05:09
#17966
Hi Jeff, thanks for your reply, I'm about to get my hands on an origional 500 parts list with numbers but its going to be a few days yetB) ,as soon as I've got it I'll take you up on that . Many thanks.Pete:)
  • wireman
  • wireman's Avatar
15 Jan 2006 07:33
#17979
i wonder if that wouldnt tend to eggshape the rings just a little making them more likely to break?
  • tellietubbie
15 Jan 2006 07:43
#17983
Probably, I'm gonna have to find another way to do this, I think its important to keep it as origional as possible so maybe another Jap 500/4 could be of use? We'll see, thank for your i/p Wireman.All the Best from England:)
  • ibsen22000
  • ibsen22000's Avatar
16 Jan 2006 11:56
#18143
Klasmo Bikes have got the STND piston rings listed.
Kawasaki parts #: 130081004
Price: 34,86 € for each set.
KLASMO LINK
  • tellietubbie
16 Jan 2006 17:05
#18184
Ibsen, you made my day:P ,thanks a lot guy!:)
  • Jeff.Saunders
  • Vendor
  • Vendor
16 Jan 2006 17:30
#18187
Klasmo is probably much quicker for you - and the prices are not too bad
If they don't have it in stock, it does look like it's available out of Japan - the approximate cost would be around $35 per piston
  • tellietubbie
16 Jan 2006 17:39
#18189
Nice one Jeff, the info on this site is IMPRESSIVE, and the clientel most agreeable.:) Thanks again Guys.:P
