Stock Exhaust (79 kz650-b3)
- rtrider73
30 Oct 2007 11:16
Good afternoon campers,
Looking to replace the 4-2 stock exhaust w/ a reasonable quality unit of like configuration. I lost a web link I had for a reseller of what appeared to be a stock replacement the 4-2 exhaust for the b3. Although if memory serves it was over $400 US.
Also, I've seen a 4-2 w/ same side canisters on a 650 in the gallery here which I also can no longer find. Does anyone have insight into that type of setup. If so that's something I'd consider as an alternative.
The ultimate objective is to stay w/ stock jetting and a classic look.
Thanks in advance to all.
Regards,
Rob
Regards,
Rob
- Bluemeanie
Re: Stock Exhaust (79 kz650-b3)
30 Oct 2007 19:27
Maybe I'm missing something but if you want that "classic" look why are you replacing your stock exhaust? Is there something wrong with it? MAC has a almost decent 4-2 system.
- kz650 Bill
30 Oct 2007 21:32
don't know if these will fit, but I have a set of original pipes from my kz650 C3
- rtrider73
31 Oct 2007 07:41
Bill,
The finish is completely deteriorated at the collectors/crossover section of the original exhaust w/ some leaking.
I didn't pick up on MAC's 4-2 offering for the KZ. I'll look into that thanks. Hopefully it will let me retain the centerstand.
~R
~R
- rtrider73
31 Oct 2007 09:04
Bill,
~R
~R
- rtrider73
31 Oct 2007 09:04
Bill,
~R
~R
- Bluemeanie
31 Oct 2007 11:53
- rtrider73
01 Nov 2007 05:11
BM,
Thanks for the link.
Does anyone know if rejetting would be required w/ the stock airbox using this system?
TIA,
~R
TIA,
~R
