- Thank you received: 3
1075 Kits: What's the difference b/w compression ratios?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
What is the difference in terms of street use? I assume that 8.5 is the "mildest" and 12:1 is more for racing? But if I went with a 10.25:1, what should I expect? Do I need to change to HD studs? Different cams? Premium Gas? Other considerations?
Thanks.
Post edited by: Skyman, at: 2007/10/29 12:09
West Linn, OR
- steell
10.25:1 is for street use and needs Premium gas.
12:1 is for racing and requires racing gas.
- Skyman
West Linn, OR
- Skyman
Thanks.
West Linn, OR
- steell
Sure gets expensive, don't it
- Skyman
Yeah, if I do this, I'll probably take it one step at a time. Maybe include the studs. Cams and springs can wait.
West Linn, OR
- steell
- wiredgeorge
- steell
I have the capability to bore cylinders, and I have a friend that owns and operates a motorcycle specific machine shop. My friend bores and hones my 750 twin cylinders (he's much better than I am and has better equipment), but since I am going for ultimate performance from my 750E project, I'm sending the block and cylinders to APE (and possibly the cylinder head, APE has a brand new Serdi).
If I had to choose between using a local automotive machine shop or sending the stuff to APE, I'd send it to APE.
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
- larrycavan
- Visitor
I am thinking about putting a 1075 kit on my B2. In looking at the APE site, they show kits available with compression ratios of 8.5:1, 10.25:1, and 12:1.
Thanks.<br><br>Post edited by: Skyman, at: 2007/10/29 12:09
My 2 cents on this....
Performance cost money....so...it's not what you spend but what you buy that makes all the difference.
There's really only 1 logical choice for the N/A street motors and that's the 10:25:1 compression ratio. If you're not going to put any compression to it, then I wouldnt' bother with a big bore kit..look into 1st over OEM pistons instead.
Jeff at Z1 has a great price on the 1075 Wiseco kits. I'd spend an extra few bucks and get an OEM KZ1000 cylinder base gasket, even though a cometic gasket comes with the kit. The cometic head gasket is fine.
Web, Megacycle and Cam Motion all have nice drop in cams that when combined with the big bore kit will really wake up a tired KZ. If you want your eyes fully opened at a reasonable cost...get some head work done and stay with stock valves. You can get by with the stock KZ1000 crankshaft if it's still in good working condition.
- wiredgeorge
As far as compression... It looks like an owner's goals should determine the compression of the piston kit. For those who are not all that interested in hot-rodding and are looking for reliability and economy, the 8.5:1 compression makes sense. I would never try and hot-rod one of my KZs because I already own a modern bike that is far faster than a most vintage street KZs. In order to make a KZ as fast as the modern bike, I would have to go a lot farther with mods than the street cams and mild displacement and compression bump.
