will this fit?
  • Rich
  • Rich's Avatar Topic Author
will this fit?
27 Oct 2007 16:02
#178394
See attached Ebay auction. It's a valve cover from a '79 KZ1000, will it fit on my '83 KZ1100? I'd like to have one that didn't have all the smog control crap on top of the engine.
Will This Fit?
Post edited by: KZCSI, at: 2007/10/27 23:17
  • racer54
  • racer54's Avatar
Re: will this fit?
27 Oct 2007 16:58
#178406
No. If you look at your valve cover or your head if you don't have a valve cover, you will see that yours has a bolt hole at the end of each "arm". The valve cover you need will sorta come to a point at the end of each "arm" and have the bolt hole. Here is one like you need.
  • Rich
Re: will this fit?
27 Oct 2007 20:07
#178441
OK, thanks. I knew there was a change at one time that made things not interchange, guess it was between '79 and '83.
  • darmahsd
  • darmahsd's Avatar
Re: will this fit?
28 Oct 2007 19:37
#178590
Rich,
You need to keep an eye on Canadian eBay. That's where I got mine, but not after missing a few due to bidding frenzys. It seems that lots of folks are looking for them. I had to pay a hundred bucks for mine but you might get lucky and pay less. You have a "J" motor, which is '81 up. Canadian and probably European versions had smooth valve covers without the "clean air" reed system above the exhaust valves. You just plug up the holes.
Stephen
