Oil level window clouded up
  • seanof30306
  • seanof30306's Avatar Topic Author
27 Oct 2007 14:30
#178383
'79 KZ650 B3
My oil level window is so coulded up I can't see the oil. Is there a fix for this, or another method of checking for proper oil level?
Also, what's the oil capacity on this engine?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Oil level window clouded up
27 Oct 2007 15:47
#178392
I assume that the cloudiness you're seeing is milky. If so it's the result of moisture in the oil which can result from the bike being stored outside but more likely is the result of the motor repeatedly being run and then shut off before it gets thoroughly warmed up. Don't make the mistake of thinking that a few miles is all it takes. Once you make sure it has oil, take it out for a fifty miler. I bet the sight glass clears up after that.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Bluemeanie
  • Bluemeanie's Avatar
27 Oct 2007 16:40
#178402
If it's the same as mine it should be about 3.7 qts with filter.
27 Oct 2007 18:11
#178417
If all else fails
Z1E Oil Sight Glass
  • RonKZ650
  • RonKZ650's Avatar
27 Oct 2007 18:52
#178423
All good advice. Like said, the oil if not warmed up will fog the window. If all else fails you can remove the cover and clean the glass. It wipes right off. The problem is not a bad sight window, it's buildup that if won't go away on it's own will need to be addressed.
I start with 3 quarts on an oil change, then check oil level. Around 3.3-3.5 quarts with filter is what it takes. Subtract about .3 quart if not changing filter. I change filter only every other oil change and have for 300 plus thousand miles.
  • Bluemeanie
28 Oct 2007 07:51
#178498
Same here Ron, I start with 3qts and add as necessary. I also change filter every other change. I change oil every 1,000 miles. My engine has NEVER seen dirty oil in 27 years! ;)
