- Thank you received: 2
sunnen portable hones
- lemo32
- The Price of Cool aint cheap
hones could also be used to bore cylinders. If so could they be used to bore 900 to 1015 and still stay within tolorences.
1979 kz 1000 06 katana 750
- Duck
- e vica na i sau na ga
-Duck
- arobsum
- Thank you received: 10
- steell
www.watsontooling.com.au/pdf/79b-87.pdf
I'll admit a Van Norman would be better, but it's not exactly portable (or cheap)
does anybody know if these portable sunnnen
Yes and yes.
Might take you 15 minutes of actual honing time (plus set up) per cylinder though.
- Duck
.125mm/min
Yep that's 16 minutes per jug.
What kind of stones are they using to get this rate with the
portable? I didn't see any specs in the link. Will look some more. I could really use one of these if they cut that fast.
OK found it. 'fast material removal up to 5 thou/min'
I'm kind of skeptical. When you spread it over the whole bore it's a lot of material.
-Duck
Post edited by: Duck, at: 2006/01/14 19:28
- craigpuckett
just my .02B)
- steell
www.sunnen.com/product.jsp?id=38&slink=y
This is the way to go if you have a pocket (maybe a house) full of change
www.kwik-way.com/products/Engine/1291.htm
Or:
www.winonavannorman.com/machines/cb2800.html
I can dream can't I
- APE Jay
It is only $95.00 to have it done. The hone cost way more than that.
Jay
- wireman
- steell
And I hate having to pay someone else to do something.
- Duck
The 0.005"/minute is the rate of material removed by the tool.
The reference surface is the area of the stones face.
It's not the rate of bore diameter increase.
Take the face area of the stone and divide it by the area you want to remove material from. Multiply this by your 0.005" min
and you will have the best rate of diameter increase you can expect.
For example:
If hone has 4 x 2" x 1/2" stones that's 4sq inch.
If bore is 3" x 8" that's 72sq inch.
Ratio is 1/18
0.005"/min translates to "up to" 0.007mm/min radius increase.
I wouldn't want to do this with a hand held tool.
Another thing to consider is stone cost....you'll use a lot of them.
-Duck
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
