KZ1000 engine in KZ650 frame?
- jordan172005
- FastKaw1
You can do it. But the first time you need to adjust the valves
you have to take the motor out to do it.
Trust me it's more hassle then it's worth.
- jordan172005
Thank you,
Jordan
- otakar
In 78 the tubes were enlarged by 1/4" on the D model for this reason and even that was not enough. The reciprocating mass on the thousand is just way too much for that frame. Also, if you rebuild the entire top end, you should re-shim the cams after the valves seat. The cam clearances get too tight. This takes about 500mi. I ride that in about seven days. Would your bike be a novelty? Yes. Would it be ride able in an aggressive manor? No. I guess that would defeat the whole purpose of putting a 1000 engine in a 650 frame.
Otto Kudrna
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- reborn650
Your best bet is to pick up a tired 1984 Gpz750 engine, cylinders and head and put it onto your 650's bottom end. You might need to put in a new beefier clutch to handle the extra power. This Gpz engine was rated around 87 hp when new which is a significant step up from the 650's 64 hp. Get your hands on a Wiseco 810 kit, clean up the head and get a set of good carbs and ignition and you should be in the right power range of a stock Kz1000 which was around the mid 90's if I recall.
Shoehorning the engine into the frame and gussetting it to handle the oversized motor is doable but as mentioned earlier, any time you have to check valves or pull the valve cover to get to a little leak this will turn into a major project.
Steell has a 650 that has a 1000 motor stuffed into the frame that had previously been put into it by another kzr member (sbjones) and if you need to see some close up pics perhaps they can help out if you ask real nice.
-1998 Jeep TJ Wrangler 4.0...
- steell
Not yet
The 650 has a 750 bottom end bolted in it at the moment, the 1000 (81 KZ1000 CSR) donor is still sitting in Omaha awaiting transportation to here.
Do have a Wiseco 1105 kit, 1100 cylinder block, and GPz1100 cams waiting for it.
So if a 1000 has to much power for the 650 frame, then I guess the 1105 ought to have way to much power (too much is not enough)
The frame will be seriously reinforced prior to installation of the motor, and it has GSXR suspension front and rear which lessons the weight and should help.
It's certainly not going to be a daily driver
The above bike is GPzInfested's (my Nephew and partner in crime, who also owns the GPz750 Turbo, and the GPz750 motored 79 KZ650 SR with GPz750 suspension) I'm building a 810 KZ750E with GSX suspension and fuel injection for myself. I prefer something I can enjoy riding, not something that will yank my eyeballs out of their sockets every time I twist the throttle. :woohoo:
Guess that means I am getting old (and maybe wiser)
Post edited by: steell, at: 2007/10/27 13:13
- CruisingRam
- Thank you received: 15
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- OnkelB
- Thank you received: 80
A member on the old Kzrider board- might still be archived there- stuffed, I believe, a Gpz 1100 motor into the 659 frame, and it fit quite nice- he canted the motor forward a bit to make motor in frame valve adjustments possible. It was one radical looking bike!
Messenger1
Messenger1 part 2
One of my favorite builds ever.
77 KZ 650 B1, 82 GPz 1100 B2.
- rstnick
- Thank you received: 377
The Red one had a good write up in the archives I believe on the mods done to fit the motor.
The blue, Z Power, had a web site on the build, but it seems to be gone.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
