replacing engine... what do I need?
  • terps19
  • terps19's Avatar Topic Author
25 Oct 2007 16:38
#178120
I am going to replace an engine that has 77k on a 1981 kz750 with another that has less than 9k (Gotta love winter projects). I am wondering what I need to do this... gasket, seal etc wise?
I am assuming that I will go into the valves and adjust them as well as clean out the carbs. So I will need a new head cover gasket? should I buy 4 new carb rebuild sets? What about exhaust gaskets?
This is my first time working with a Kaw and I dont like the Haynes manual for this model. Should I invest in a Kawasaki factory manual? I see some online but they are a bit pricey.
This is a great site by the way.
Thanks!!!!!!!!!!:laugh:
  • fixer5000
  • fixer5000's Avatar
Re: replacing engine... what do I need?
25 Oct 2007 16:53
#178124
i would buy the factory manuals. they are invaluable for these bikes and not that exspensive to buy. yep id adjust valves or at least check the clearances, replace top cover gasket and why not rebuild the carbs too? easy doings for winter boredom round here. lots of good advice to be had on this site too just ask...steve
1978 kz650b pretty much stock
massachusetts
  • The Milkman
  • The Milkman's Avatar
25 Oct 2007 19:57
#178157
If your old engine was running well, why not just swap the carbs to the new engine then rebuild the ones off the new engine in your leisure. If you are sure the engine only has 9k on it,, do a compression and leak down test to check the rings and valves, if it shows good, do valve adjustment check to be sure they are ok. And replace the valve cover gasket. Get new exhaust rings and it seems you would be good to go.
Ride safe
  • terps19
26 Oct 2007 09:57
#178250
Thank you milkman and steve!
Unfortunately I cannot do a compression test as the bike with the engine with 9k doesnt have the wiring harness on it anymore and doesnt have a battery also the ehaust pipes are off... I figure instead of putting the bike back together to do a compression test, I just swap out the engines and then do a compression test. If need be I believe that I can check and adjust valve clearances with the engine in the frame???
Or if there is an easier and or better way I am always open and will porbably take your suggestions.
So as of now this is the start of the list:
1. Valve cover/top gasket ($$?)
2. 4 carb rebuild kits (are they really $35 for each carb???)
3. Exhaust rings
4. Factory manual
  • loudhvx
  • loudhvx's Avatar
26 Oct 2007 10:04
#178251
Be careful un-bolting the engine. The one-way nuts sometimes strip the bolts. The bolts are $$$$.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
26 Oct 2007 11:30
#178259
Do what I did when I wanted to check a used engine(~5000 miles on it). I transfered "said" engine, hooked everything up, and it started, but ran a little odd. I performed a compression check, and found one cylinder very low to the others. Performed a valve clearance check, and saw that one exhaust wasn't measureable, so I adjusted(reshimmed) it. Ran fine afterwards.
-I'd recommend checking the valve clerances before starting.
-No telling how long it's been sitting, so add a little engine oil in the spark plug holes, and turn it over by hand.
-Replace the engine oil and filter with fresh, and turn it over by hand or with power before starting.
-I removed the oil pan on mine, to see if there's issues(silver shavings, previous owners watch... :lol: ) inside. Luckily there wasn't anything. My engine was sitting for more that 8 years.
'85 GPz550(ZX550-A2)
  • terps19
26 Oct 2007 13:10
#178270
I hope I am as lucky as you Corey. And thanks for the information. I have a question though.
You say to turn the engine over by hand... I dont think I have a kick starter on my 81 KZ750 E2... so how do I turn it over by hand? Might be a real stupid question but forgive me pls!! :laugh:
thanks
  • CoreyClough
  • GPz550 Addiction
26 Oct 2007 16:29
#178289
Remove the right side ignition cover. There's a bolt you can put a socket on, and turn it over. Remember to remove the spark plugs, as this will make it easier. Turn it clockwise.
If you have the engine installed, and the chain hooked up, put the bike in 3rd gear(spark plugs removed), and spin the rear wheel in normal rotation.
  • terps19
29 Oct 2007 10:40
#178670
Just a little update...
I got the first engine out of the first frame this past weekend. It wasnt really as hard as I thought but I think putting the engine back into the frame will be a little harder.
Should I check the valve clearances now or wait until it is in the frame?
Do you guys think I should totally rebuild the better carbs? I think this would require 4 rebuild kits that are about $15 each... does this sound right?
Hopefully I will have the other bike prepped this week and have the second engine out and maybe even bolt in the 8k mi engine in the nicer looking frame!
Exciting times!
