KZ1100 Cam Cap Bolt Stripped
- wilk
What do I do?
- Samwell
- Thank you received: 1
I'm working on a re-build of a KZ1100-A2 Shaft 1982 and as I was putting the cam shafts back in, 3 of the 8 exhaust camshaft cap bolts would not torque up to the 144 lb. in. (They stripped). Upon closer examination, I see that a previous owner inserted helical inserts and they are now blown.
What do I do?
Ouch! Camshaft caps are machined with the cylinder head. So your choices are limited to repairing the mangled holes or getting a new head with camhaft caps in place. You can repair the holes with new helicoils. Removing the head will make drilling easier. Another option for thread repair is a timesert. See this webpage: www.timesert.com/
Hope this helps...Sam
- Thank you received: 2829
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- racer54
- Thank you received: 114
- APE Jay
- Banned
- Thank you received: 58
I have a nice KZ head that is missing a cap. Everyone I have tried in it locks up the cam.
Jay
Post edited by: APE Jay, at: 2007/10/21 21:11
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
West Linn, OR
- wilk
Had the same problem on one of my heads. PO had used helicoils which came out. I drilled it out and re-tapped for an M8 bolt. Worked great.
I was thinking about that but I wondered how i Would get around the dowel pins? Two of the 4 screws on each cam cap have dowel pins. How did you deal with that?
- wilk
way too tight, you can replace the heli coil or use a time sert, and recheck the torque
See attached page from service manual which suggests 12 lb. ft. for the 6 mm bolts
Post edited by: wilk, at: 2007/10/22 13:23
- wilk
- Skyman
In my case, only one of the holes with bad threads was on a dowel pin hole. I only had to do two bolts. The other threads were all still good. So on the one with the pin, I just took the pin out. I put the other three bolts in to try to make sure it was lined up right. Maybe not the right thing to do, but that's what I did. Just be careful to try to keep everything lined up when you drill it. And use a drill press, of course.
I didn't do this, but now that I think about it, I probably should have drilled it with the valves removed and the cams mounted, just to make sure everything spun freely before drilling.
Post edited by: Skyman, at: 2007/10/22 13:43
West Linn, OR
- wilk
I think I'll go for the oversized bolts. I'll make the drilled hole thru the cam cap big enough so that it should self align with the cam and I also will have at least one dowel left in a hole which is still working which should be enough. (I don't feel like removing the valves again, I had them out and sweated for about 2 hours putting them back together.)
