Cleaning my Engine inside and out.
- jimyed
13 Jan 2006 12:00
Hello everyone.
I am rebuilding the engine on my KZ550 over this winter. I have the top end disassembled for the most part (heads off but not apart) so far everything looks okay to rebuild. I have VERY little cash so I am doing this on a shoestring. Aside from taking the parts into a shop for clean up does anyone have any ideas on how to get the Gunk off? Specifically in want to clean the Oil/Dirt from the out side of the motor and the carbon etc. from the ports, Valves and pistons.
Thanks.
Thanks.
- Biquetoast
- King Jeremy The Wicked
Re: Cleaning my Engine inside and out.
13 Jan 2006 12:19
For the outside gunk, I read people praise Sinple Green, so I got some and tried it. It actually works pretty well, if you use alot of it and leave it on for a bit.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- wireman
13 Jan 2006 14:06
for the aluminum stuff the best way i know is glassbeading,but you have to have everthing apart and make sure you clean everything afterwards very good!goodluck,happy wrenching!
- OKC_Kent
13 Jan 2006 14:25
I cleaned my engine with a ZEP orange degreaser I got at Home Depot. Spray it on. let it sit, scrub a bit, rinse off. It worked good, but took a few cycles and I had to buy a few different brushes to get in all the nooks and crannies. It's harder to do with the engine in a bike, but if yours is taken apart it should be a breeze to do in the sink or bathtub.
You can clean the cases in your dishwasher, when the wife is gone. Try a test piece as the detergent may discolor the aluminum a bit. Search the web for this beforehand. Need a good clean water rinse after. Just run another cycle without soap.
Oven cleaner will clean cases good, but again will discolor the aluminum if left on too long.
Then you can always take the cases to the pressure car wash and blast it.
Check this link out, good stuff about aluminum cleaning. Someone there said carb cleaner will take carbon off pistons. I haven't tried it yet.
www.thevincent.com/vinpolish.html
Post edited by: OKC_Kent, at: 2006/01/13 17:36
Cashion, OK
78 KZ650 B2 85,000+ miles
- kzcory
13 Jan 2006 16:12
if you have the top end of the motor off you can have them tank boiled and crack checked. It won't cost much and it will get the gunk off. It WILL NOT however remove all of the corrosion and stains deep in the aluminum. It doesn't cost that much and will save a lot of headaches from screwing around with degreaser. I have had luck with a product called "greased lightning" It must have some type of acid in the formula because it cleans off the grime, and leaves the aluminum with a dull but very clean look.
- RomSpaceKnight
16 Jan 2006 12:39
Biodegradeable degreaser, soap and water, WD40 (actually cuts grease and grime pretty good), solvents (turpentine, varsol, gas (be careful, wear gloves, no fire, watch for rubber parts)), elbow grease, SOS pad, stiff brushes
