- Thank you received: 15
Best compression ratio neccesary for .420 cams
- CruisingRam
21 Oct 2007 22:35 #177502
by CruisingRam
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
Replied by CruisingRam on topic Best compression ratio neccesary for .420 cams
Hmm, lots of good info here- looks like I may be porting some heads here soon, with someone that really knows these engines and has done hundreds of Z1 heads before.
I have ported heads before- just not Kawi heads.
So what is the power band on the 410 and the 420 cams? with 1000cc's and ported heads and 10.5 to 1 compression pistons?
I want to get a good baseline tune with carbs before I jump to EFI, and I want the motor to be done!
- mark1122
- Keep twisting it
- Thank you received: 109
22 Oct 2007 07:38 #177548
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Best compression ratio neccesary for .420 cams
I had rc400 .424 lift 260 duration @.050" cams last year(similar to web #109) and they pulled harder at 7000rpms .i now have a web cam similar to the ape k410 but a little broader all around.it is.415" lift 252* dur @ .050" (web grind #493). i find there isnt a big dif between the 2. but i dont feel the pull at 7000 rpm any more. it is more even all around.see sig bellow for bike specs. 10.25:1 wiscoes with 155 psi compression.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- nads.com
- Thank you received: 20
17 Jan 2011 22:30 - 17 Jan 2011 22:36 #423187
by nads.com
Replied by nads.com on topic Best compression ratio neccesary for .420 cams
BSKZ650 wrote:
sorry sleep walking again.
compression ratio is a factor from volume of the head (cc,s ) and the dome of the piston, the valve overlap can play a small part but the tighter the chamber the higher the comp ratio.
I dont think I have ever installed a cam that made any real changes in the compression ratio, and changing the degree of the cam made no differance either, but it does make the motor respond
Last edit: 17 Jan 2011 22:36 by nads.com.
