chain links???
  • boomboom45
  • boomboom45's Avatar Topic Author
chain links???
18 Oct 2007 14:39
#176946
anyone know how many links are in a chain for a kz 650d?
  • Bluemeanie
  • Bluemeanie's Avatar
Re: chain links???
18 Oct 2007 14:41
#176947
102 comes to mind?
  • OKC_Kent
  • OKC_Kent's Avatar
Re: chain links???
18 Oct 2007 16:45
#176972
I know a B model is 102
Cashion, OK
78 KZ650 B2 85,000+ miles
  • JimatMilkyWay
  • JimatMilkyWay's Avatar
Re: chain links???
18 Oct 2007 16:46
#176973
Timing?
  • RonKZ650
  • RonKZ650's Avatar
Re: chain links???
18 Oct 2007 19:10
#176996
It's 102 links. There's a NOS Kawasaki endless chain on ebay right now. I highly recommend this chain over modern chains. (Don't know exactly why I guess, but I've used both and prefer the endless). Yes you need to remove the swingarm. Well worth it because it needs clean and lube anyway. This is like a $400 chain through Kawasaki. By the time you fight that damn bastard master clip on a modern chain, plus break your old chain to remove it, you could be quicker to just remove the swingarm and use the endless.
tinyurl.com/2ybvaq
Post edited by: RonKZ650, at: 2007/10/18 22:12
  • boomboom45
Re: chain links???
19 Oct 2007 19:17
#177145
thanks for the help guys. like i have always said, ask the pro's, the guys who own the bikes, not the bike shop. local kawa shop said 110
Re: chain links???
19 Oct 2007 19:23
#177148
110 ?? Did they try to sell you an extended swing arm with the chain??:P
  • Saki Jockey
  • Saki Jockey's Avatar
Re: chain links???
21 Oct 2007 21:34
#177496
Probably trying to flog old stock, sell 110, cut to 102.
Rob A.
550 A4
GTA,
Ontario, Canada
  • boomboom45
Re: chain links???
27 Oct 2007 07:20
#178335
actually when it comes to the old kawa's i have found they are complete idiots.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: chain links???
27 Oct 2007 07:54
#178342
If you're using the stock tooth sprockets, www.buykawasaki.com should list the chain type and how many links it needs to be.
If you have a 650 D it should be a 102 links using the stock 16/40 sprockets.
'85 GPz550(ZX550-A2)
