- Thank you received: 1
Backfire.. No start.
- CptEDIV
Thanks,
1979 KZ 650 D2 \"Midnight\" blue.
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- CptEDIV
Thanks,
- wiredgeorge
- ten6
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- CptEDIV
- OKC_Kent
- Thank you received: 20
Post edited by: OKC_Kent, at: 2007/10/18 13:29
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- CptEDIV
- Thank you received: 2098
...when I give it gas, the RPMs go up and stay for about 2-3 seconds, before returning to about 1, and then idles rough. I can start it, get it to a good sound idle at 1- 1 1/2 RPM, but if I rev it, it stays up then when comes down I have to set the idle higher or constantly give it a little gas to keep it running....
Might be air intrusion at carb holder. Try spraying WD40 around carb holders while bike is idling. Intake of WD40 will result in smoke from the exhaust and likely engine stall.
P.S. -- Leak might also be from bad cap on a vacuum nipple.
Post edited by: Patton, at: 2007/10/18 14:03
- CptEDIV
...I'll spray down the carb holder, thanks.
Just to confirm -- the spray should be around the carb holders where the carbs are connected to the engine (not where the carbs are connected to the air-box or pods).
Post edited by: Patton, at: 2007/10/18 14:26
- CptEDIV
What do I do after that?
Thanks,
