Stator cover?
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
Stator cover?
16 Oct 2007 08:55
#176426
I know there is a classified section but I think it might work better here? Cannot locate one of these on ebay (all older ones) Anybody have one that is in good shape that can be polished up?
Re: Stator cover?
16 Oct 2007 16:00
#176515
These are a bit pricey, but I thought you might find them interesting as they both claim to be from '79 KZ650s. And yet I've seen other '79s that are smooth (no ribs). I wonder if different models had different covers.
cgi.ebay.com/ebaymotors/1979-Kawasaki-KZ...dZ1QQsspagenameZWDVW
cgi.ebay.com/ebaymotors/79-KAWASAKI-KZ-6...dZ1QQsspagenameZWDVW
Here's one that claims to be an '81:
cgi.ebay.com/ebaymotors/81-Kawasaki-KZ65...dZ1QQsspagenameZWDVW
Then there is this "bargain"
cgi.ebay.com/ebaymotors/Kawasaki-NOS-KZ6...dZ1QQsspagenameZWDVW
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: Stator cover?
16 Oct 2007 16:13
#176519
I've got one here that will work for you. Do you need the stator too or just the cover? I'll hang onto it for you until you are ready for it and then we can work something out. I'm sure there are other things taking up your cash at the moment.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • RonKZ650
  • RonKZ650's Avatar
Re: Stator cover?
16 Oct 2007 16:19
#176522
All the 650s I've ever seen or owned that were 77-79 models all used the plain cover. In 1980 on the KZ650s and 750E they started using the cover like the $139 pictured one. I doubt the stator from an early cover would mount to a late cover or vise-versa.
  • Bluemeanie
Re: Stator cover?
16 Oct 2007 17:44
#176547
650ed, Where did you find those? I've been looking under KZ650 / parts & accesories and KZ / parts & accesories. I've been living at these two places for a month and you pop up these!? What are you looking under??
Re: Stator cover?
16 Oct 2007 18:00
#176552
Bluemeanie,
I went to eBay.com; then next to "all categories" I plugged in:
cover (stator, generator, left) ("z 650", "kz 650", kz650, z650)
Give it a try, you should see an additional one out there that is just a little expensive (unless you hit the lottery):
cgi.ebay.com/ebaymotors/1980-1983-Kawasa...dZ1QQsspagenameZWD1V
  • JMKZHI
  • JMKZHI's Avatar
Re: .
16 Oct 2007 18:59 - 03 Dec 2008 07:39
#176569
del
Last edit: 03 Dec 2008 07:39 by JMKZHI.
  • Bluemeanie
Re: Stator cover?
16 Oct 2007 19:16
#176572
650ed... Tried it and works great. Never thought about looking for an "item" by itself. I thought all old KZ parts would be grouped together where I was looking. Thank you... John (brain dead) :woohoo:
JMKZHI... I wish it was. That was just for demonstration purposes. Mine is in pic below. But thank you for painting tips! :)
  • loudhvx
  • loudhvx's Avatar
Re: Stator cover?
16 Oct 2007 23:19
#176615
Also (I assume you know the 77 system is totally different), but the stators are either 3-phase or 1-phase (like yours). The way to tell them apart is the 3-phase has 18 legs on it while the 1-phase has 12 legs. If a 3-phase will fit physically, you can use it with the rotor for a single phase and vice-versa as long as the spacing is the same and the gap between rotor and stator are similar (bigger gap = weaker charge).
I don't really know if 3-phase stators are the same size as 1-phase or not. (I think they are in the 550 family so maybe they are in the 650/700/750 family too.)
