lockhart oil cooler
  • arobsum
  • arobsum's Avatar Topic Author
lockhart oil cooler
14 Oct 2007 07:36
#176112
what do you think would be a good price for one of these in good shape? no extra fittings, just the cooler. i know a guy that will sell me one for $25.00....i'm not sure my old kz1000 really needs one...do most of you guys run oil coolers?
  • themachine
  • themachine's Avatar
Re: lockhart oil cooler
14 Oct 2007 07:42
#176113
its reccomended, your engine is oil cooled as well as air.
its like putting a bigger trans cooler on a fast musclecar, if your going to drive it for long periods and pound on it in hot weather it will give the trans a longer life period therfor saving you moneys.
i paid 19$ on fleabay -shipping for my gpz cooler, and it came with the lines but not the fittings so 25 sounds fair if its in healty shape.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
14 Oct 2007 09:42
#176125
I've had my bike for 30 years and never used or needed an oil cooler, but my 650 is stock so it cools itself very well as originally designed. Your bike isn't stock, so it may be generating heat beyond the cooling capacity of the fins. You might first find a way to measure your oil temperature to see what temperature it's running at. If it's pretty hot, and you add an oil cooler, you could then see how much difference the cooler makes. I think we would all be interested to see the results. Ed
  • nads.com
  • nads.com's Avatar
14 Oct 2007 15:09
#176161
driving long periods keeps the temp in check, even if it's hot weather, it's when u slow down the temp rises. And it rises fast. Driving on the freeway I reach down and hold my hand to the alt. cover. I should be able to hold it against for at least a few seconds. When i have to jerk my hand away almost immediatly, the motor is running hot. Doesn't matter how fast or hard I drive the bike, the motor never gets so hot I can't hold the cover. Only time it gets that hot is in town and it depends on the outside temp. Without any air to carry the heat from a cooler how is it going to lower oil temp? I spoz it cools between stop lights pretty and that's where u get the temp reduction.
  • arobsum
14 Oct 2007 15:21
#176165
i've heard pros and cons on this subject before with each side having good points....i guess i wanted to hear some things from folks who actually use one before i dropped 25$ for something i probably wouldn't need...but on the other hand, having one on my bike really wouldn't hurt either..:S :blink:
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
14 Oct 2007 19:04
#176197
"having one on my bike really wouldn't hurt either.."
Are you sure? Guess I didn't check your ride first but the roller bearing KZ's run low oil pressure. While I've never added one I've seen a number of "I've just added an oil cooler, where did my oil pressure go?" type of posts.
If there's one thing that no one disputes it's that Ma kaw builds a stout engine. If you've hopped it up a bunch consider an oil cooler, if not:
Trust in the Kaw!
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • BSKZ650
  • BSKZ650's Avatar
15 Oct 2007 14:48
#176282
the heat we have here in the summer makes me think I need one, well I have one, I think it is good insurance to try to keep the oil temp in the cool working range
77 ltd1000, current rider
76 kz900, just waiting
  • arobsum
15 Oct 2007 15:06
#176284
Trust in the Kaw!
KZCSI
good point. i didn't think about the low oil pressure........i may just keep it as a spare or ebay it later.:dry: :whistle:
