KZ 1100-A2 1982 cylinder head question
- wilk
10 Oct 2007 04:20
On my project KZ 1100-A2 Shaft 1982, I've taken the head apart and found that the exhaust valve guide on cylinder #4 slides up and down in the head. I ordered a new valve guide (49002-1002) but I'm not equipped to remove old guide and replace with the new one. Also, I'm not sure the new one will not slide also.
Has anyone ever heard of this problem and what can I do to solve?
- Mcdroid
- Gone Kwackers
Re: KZ 1100-A2 1982 cylinder head question
10 Oct 2007 06:56
Hello and welcome, wilk. Is the guide loose enough that you can easily move it...or has it merely moved in the head?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- steell
10 Oct 2007 07:46
Oversize valve guides are available (check KzZone, AKA APE), they may not be oversize enough, depending on how big the hole is now.
- wilk
10 Oct 2007 12:22
Mcdroid wrote:
Yes, I can move it up and down by about 3/4" by hand between retainer clip at top and carbon build-up on the bottom.
- Mcdroid
- Gone Kwackers
10 Oct 2007 12:38
Wilk...Yikes!...follow steell's advice and contact APE (KZZone) [look on the right hand side of the page for a link under THE ESSENTIALS]. You'll eventually chat with Jay at APE and he is very helpful. This problem is something that may be beyond an easy fix:(
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- APE Jay
10 Oct 2007 17:20
Our first oversize is .004". That may be too big. When we run into this situation, we custom machine a guide to the right size.
We would need to have the head to see what size the guide needs to be. Also, after installing the guide, that seat would have to be recut. May as well do them all.
Jay
Post edited by: APE Jay, at: 2007/10/10 20:21
Jay
- wilk
10 Oct 2007 19:31
APE Jay wrote:
This is a budget re-build as I don't know how the rest of the bike works. What is the difference in price to fix 1 valve vs. 8?
Jay<br><br>Post edited by: APE Jay, at: 2007/10/10 20:21
- wiredgeorge
11 Oct 2007 07:14
I keep a couple of carburetor test bikes running. When I run into a situation similar to the one you face, I just replace the head with one that doesn't have a problem using a spare. I keep a couple good spares on hand just for this purpose. If you are trying to do this project inexpensively, you may want to buy a spare head from eBay and hopefully, it will not have similar issues.
- wilk
11 Oct 2007 12:02
Thanks all for your feedback. I finally found a specialized local machine shop dedicated to performance motorcyle work. They will machine out the guide and put in a new oversized one for $135. Expensive but they seem experienced and i think it will get done properly.
