Re-freshing 74 Z1-900 motor
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
09 Oct 2007 23:54
#175503
Ok, in a few week's the 900 is coming apart to be fully restoredB) B) . I wanna refresh the motor internally. She only has 20,000 miles, i know i need to shim the valves, and i think it needs valve seel's cause it smokes a bit, but dosent use a significant amount of oil. Know i was reading that i should replace all the cam chain related rubber parts, is this info right? If so were can i get them. I want to keep the motor stock. If anybody has any info on this please let me know, it will be greatly apreciated.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • inline4
  • inline4's Avatar
Re: Re-freshing 74 Z1-900 motor
10 Oct 2007 03:24
#175504
www.z1enterprises.com/
'Nuff said.:laugh:
  • donthekawguy
  • donthekawguy's Avatar
10 Oct 2007 03:29
#175505
You might think about a new set of rings also. It won't hurt and will ony cost another $100 or so. Replacing all the rubber cam chain parts will require taking off the cylinders anyway so you might as well do it while you have it apart.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • zippy
  • zippy's Avatar
10 Oct 2007 08:28
#175545
You can also get the stuff from Schnitz
secure.mycart.net/catalogs/index.asp?category=19077&count=1
Zippy
  • themachine
  • themachine's Avatar
11 Oct 2007 03:06
#175640
order a 1260 kit and tell everyone its stock. :whistle:
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • patmann
  • patmann's Avatar
11 Oct 2007 06:36
#175659
What you have read and heard is correct. All those little hard rubber dampners get rock hard and brittle with age and heat. Mine looked just fine, until I looked a little more. ROCK hard with small cracks !:pinch:
The last thing you want is a $3-5.00 internal timing/ cam part going bad on you and smoking your engine.
While you are in there, check EVERYTHING!!!! When in doubt.. REPLACE IT! You will be glad you did in the long run.
Are you restoring your bike as you said, or rebuilding/ refreshing it??
Two completely different things;)
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • oldkaws4ever
15 Oct 2007 16:31
#176300
well patman, im restoring the bike to stock, and refreshing the rubber parts and gaskets in the motor. Hope that helps
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • arobsum
  • arobsum's Avatar
15 Oct 2007 17:34
#176313
'Nuff said.:laugh:
i second this...excellent customer service with a good price.
  • patmann
  • patmann's Avatar
16 Oct 2007 07:01
#176402
Then I take it you won't be needing that Kerker..??:whistle:
Just let me know if you would please.
Pat
