- Thank you received: 43
Aluminum Cam Cover Plugs
- 79MKII
- Love Them Kaws!
06 Oct 2007 21:44 #174995
by 79MKII
The Kaw List:
Aluminum Cam Cover Plugs was created by 79MKII
And here's the next little road block in my MKII rebuild project...
I had my aluminum cam cover plugs chrome plated along with some other parts and now they don't seem to fit properly. My question is this - how far above the head can the plug protrude and still have a good chance of sealing?
I'm thinking about having them machined down or maybe just buying some new ones. Just to make sure I remember correctly, they should be pretty much flush to the head when installed, right??:S
They were originally the blue anodized Manley plugs but were badly faded. Anyone remember if the aftermarket plugs mount flush?
Thanks
Thanks
The Kaw List:
- StreetfighterKz
- Thank you received: 117
07 Oct 2007 09:33 #175045
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic Aluminum Cam Cover Plugs
The plugs should fit flush with the top of the head. The chrome plating will build up the height and cause them to fit improperly.
Seat them the best you can and them take a file and see if you can't level them out with the head. Getting through the chrome plating to the aluminum will be the hardest part.
Later, Doug
Later, Doug
1989 Vmax
- PLUMMEN
- Thank you received: 104
07 Oct 2007 15:11 #175100
by PLUMMEN
Replied by PLUMMEN on topic Aluminum Cam Cover Plugs
sand them down a little at a time on top and bottem radius,i always rough up the mating surface just a little on plated parts or they leak on me:S
- APE Jay
- Banned
- Thank you received: 58
- 79MKII
- Love Them Kaws!
07 Oct 2007 18:17 #175115
by 79MKII
The Kaw List:
Replied by 79MKII on topic Aluminum Cam Cover Plugs
Thanks for the replies - I thought they should be flush. It's amazing how thick the triple plating process actually must be. These are WAY off now. It's going to take a lot of sanding...
The Kaw List:
- 79MKII
- Love Them Kaws!
22 Jul 2009 11:37 #308684
by 79MKII
The Kaw List:
Forgot to update this thread...
I gave up on the sanding idea and bought new APE plugs. Problem solved!
The Kaw List:
- saxjonz
- KawboyZ
- Thank you received: 76
23 Jul 2009 18:06 #308911
by saxjonz
79 LTD B3
Replied by saxjonz on topic Aluminum Cam Cover Plugs
It's soooo easy to polish the aluminum to look like chrome why anyone would waste money plating them is beyond me. Seriously I had some nice black ones they lasted only a month before they began to fade. I didn't like that so much and so I grabbed some steel wool and rubbed the black right off and then took my dremel and not even 10 minutes later they looked like chrome.
79 LTD B3
- saxjonz
- KawboyZ
23 Jul 2009 18:06 - 23 Jul 2009 18:10 #308912
by saxjonz
79 LTD B3
You can even see the reflection of the houses on the paint. Not a great pic but I can say the blue is my favorite color. They will last awhile before they too fade. If they do don't discard them. Steel wool them carefully so that you only get the anodizing off and the aluminum is smooth it will look better than chrome when you finish and you will always be able to keep them up whereas chrome pits. You won't even need to sand it by the way.
79 LTD B3
Last edit: 23 Jul 2009 18:10 by saxjonz. Reason: added to post
