replacing clutch
  • mcintyreruss
  • mcintyreruss's Avatar Topic Author
replacing clutch
05 Oct 2007 20:43
#174838
any thoughts or suggestions?
got clutch, heavyduty springs, and clutch cover gasket
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: replacing clutch
05 Oct 2007 22:10
#174849
Let the fiber plates sit overnight in motorcycle-specific oil, before installing them.
What year bike, and any modifications to the engine?
'85 GPz550(ZX550-A2)
  • mcintyreruss
06 Oct 2007 09:05
#174885
81 kz550, engine stock, let them sit in oil? what does that do?
  • The Milkman
  • The Milkman's Avatar
06 Oct 2007 09:12
#174887
The bikes have an oil bath clutch (they run in the engine oil). You let them soak in oil so they are ready to go when you put them in.
  • RonKZ650
  • RonKZ650's Avatar
06 Oct 2007 10:35
#174902
I still say letting them sit in oil does absolutely nothing. You can take a clutch plate out of an engine thats had oil in it for 25 yrs, wipe off the plate, run sandpaper across it and see the plate is dry once oil is removed from it. Oil does not soak into the fiber material. You put new dry plates in an engine, the instant you put oil in, the plates are oiled and ready. Just my opinion, do as you like. Soaking in oil takes no effort really, so do it if you feel the need. I don't.
  • mcintyreruss
06 Oct 2007 16:34
#174961
thank for the help, clutch in and working fine. adjustment was backwards from what the manual said, but i got it worked out
  • Kiwiz
  • Kiwiz's Avatar
07 Oct 2007 02:34
#175004
Ball and ramp adjuster?
