Top End Failure
- Secondtime
Top End Failure
05 Oct 2007 05:57
I just got my kz1000 1977 fired up last night after changing the timing chain and notice oil dripping from the front of the head above the exhaust. There was a hole in the head. Took it apart to find that a shim had dislodged and was smashed thought the front wall by the cam. Can I fix the whole or do I have to replace the head? Has anyone seen anything like this happen before?
- wiredgeorge
Re: Top End Failure
05 Oct 2007 06:18
Surprised you didn't hear the shim come out and clatter around. I suspect you can get the hole welded shut; perhaps even JB Weld it. If I tried to JB Weld, I might use some modeler's clay to form a dam to hold the epoxy in place as it dries/cures. I suspect plumber's putty would also work.
- themachine
Re: Top End Failure
05 Oct 2007 15:07
so the bike actually ran like that, no clang clang, misfiring, ect ect?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- 77KZ650
Re: Top End Failure
06 Oct 2007 20:16
are you running some big cams? (maybe you need to go with shim under buckets?)
07 MDP Rookie of the Year
- APE Jay
