cleaning motor, inside and out.
- jordan
02 Oct 2007 19:31
I have the top end completely off of my 81 750 motor. All that is there is the bottom end. The oil pan is also off. While trying to scrape off the gasket, I got quite a few gasket pieces that fell down around the crankshaft. I was wondering if it would harm anything if I pressure washed around the crank through the cylinders, and let the water run out the bottom, and then take an air hose and blow everything dry? Would rust occur, anything seize up? Just curious, wouldnt want to screw up my motor after getting this far in the build.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- themachine
Re: cleaning motor, inside and out.
03 Oct 2007 03:04
brake parts cleaner, i hosed down my crankase and havent had a problem.
make sure you bathe the insides with motor oil after your done.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- pstrbrc
- '81 GPz 1100 project
03 Oct 2007 05:54
I concur. However, avoid using comressed air to dry it out. Don't want to force any bits into anywhere you don't want them.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- Bluemeanie
03 Oct 2007 13:37
Brake clean works great and it evaporates right away. Buy 4-5 cans, goes fast!
- reborn650
05 Oct 2007 14:01
I used a pressure washer and then sat the motor on a steel plate that was on top of an electric radiator. I left it overnight and it dried pretty quickly although there was a little bit of surface rust where some droplets dried then gave a quick spary with Liquid Wrench spray lubricant into every nook and cranny.
Worked great for me.
Cheers - Colin Firth-Ontario Canada
-1998 Jeep TJ Wrangler 4.0...
