GPZ head. Power adders?
  • jordan
  • jordan's Avatar Topic Author
01 Oct 2007 18:53
#174069
I finally got my hands on a set of Gpz cams and a head for my kz750. The head is definately gonna have to be cleaned up. Seats cleaned up, grime removed. I suppose the valves will have to come out to get everything cleaned up real good. I want to try to get a little extra power out of the head. What are the options that you guys have done, or know works? Shims, porting, anything?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • reborn650
  • reborn650's Avatar
Re: GPZ head. Power adders?
01 Oct 2007 19:21
#174079
Here is a good site to give you a little info on punching up the 750 motor.
gpzrider.lagemann.org/technical/FAQ2000.htm
You might want to consider porting the head's intake and exhaust runners and milling the surface to clean up any divots or nicks on the mating surface. Do a search in the archives for these upgrades and you can then decide on how much you want to do to the head. The porting and polishing you can do yourself with a variable speed drill and an aluminum cutting/grinding bit.
I would simply clean up the whole head, check the valves, seats, springs, retainers, valve seals and shim settings and call it a day. If the valves look like they aren't seating properly take the head to a machine shop and have them do a valve job.
You will probably be quite impressed with the power gains from the GPz head and cams over the stock Kz750. A new head gasket would also be on my to do list.
-1998 Jeep TJ Wrangler 4.0...
  • jordan
01 Oct 2007 19:37
#174080
shims under buckets?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • steell
  • steell's Avatar
01 Oct 2007 19:58
#174084
If your 750 (either KZ or GPz, except the twins) don't already have shim under buckets, then something's screwy :D
They are stock on all the 650/750 fours.
  • donthekawguy
  • donthekawguy's Avatar
01 Oct 2007 23:40
#174098
Make sure you have 83 or 84 cams. They are supposed to be better. Also there is a 810 kit on ebay right now for $390 new.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • jordan
02 Oct 2007 19:23
#174268
Yep, my cams and my head are from an 83. Sounds like a good deal on the pistons though, but I already got mine.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • donthekawguy
03 Oct 2007 00:58
#174306
If I had the cash I would get them for sure.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
