Largest bore on stock block?
  • ricerocket
  • ricerocket's Avatar Topic Author
01 Oct 2007 17:08
#174041
My question is what the largest i can go with boring cases? i have a block and 1260 bore i want to use.
  • donthekawguy
  • donthekawguy's Avatar
Re: Largest bore on stock block?
01 Oct 2007 23:42
#174099
I think it is 1115 or something like that. With your block you will have to bore the cases.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • racer54
  • racer54's Avatar
02 Oct 2007 01:51
#174101
Largest stock bore ona 900 block is the 1015 but you can bore a 1000 block out to 1105. This will leave the cylinder very thin and is not suggested for street use, although there are some out there. Best to stay at 1075 for 1000 blocks. Any larger than 1105 needs new liners that can be used on 900 or 1000 blocks. With the larger liners, you will need to open up your cases for them to fit.
  • themachine
  • themachine's Avatar
02 Oct 2007 03:10
#174102
i got my 1170 to fit by filing some flashing off in the cases.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • tjettim
  • tjettim's Avatar
02 Oct 2007 03:12
#174103
Anything larger than 1198 I recommend
a big block.
  • PLUMMEN
  • PLUMMEN's Avatar
02 Oct 2007 12:16
#174165
ditto;)
