Starter clutch qwestions
  • KaZooCruiser
  • KaZooCruiser's Avatar Topic Author
01 Oct 2007 15:27
#174009
Seems like a fairly common problem.
Looks like the project is becoming unavoidable.
In reading through the FSM, it appears fairly straightforward.
But I don't have any special tools, and would prefer not to buy them, or even think about them, if the job can be done without them.
From what I recall, it seems the easiest way to do this thing while the engine is in the frame is to pull the exhaust and clutch pack, and then lay the bike down on its side.
Any ideas welcome.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Starter clutch qwestions
01 Oct 2007 15:43
#174017
I never tabbed it in my favs and I'm to lazy to look for it right now :P :laugh:, but OnkelB has a really great write-up with pics in the archives on doing this exact repair on his KZ650.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
01 Oct 2007 17:29
#174049
RRRR, if you could point me/us in the right direction, I would greatly appreciate it. I've searched the archives for onkelB's posts on starters and such but can't seem to find the correct one with pics. All help with this would be greatly appreciated.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • RonKZ650
  • RonKZ650's Avatar
01 Oct 2007 18:32
#174063
Don't bother trying to do it without pulling the engine is my advice, but do it whichever way you think best.
01 Oct 2007 19:07
#174075
I think you might have entered an incomplete subject line into the search field - "starter" instead of "starter clutch". ;)
That being said, I checked and do actually have OnkelB's thread saved to my favs on the archived site:
starter clutch fix.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • flht1997
  • flht1997's Avatar
01 Oct 2007 19:45
#174081
i would vote for pulling the engine. i have done it both ways, and with the engine out it was just alot easier.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • gaillarry
  • gaillarry's Avatar
02 Oct 2007 03:19
#174105
I just did my GPz750 starter clutch last week, with the engine in the frame. I used a large mirror on the ground to assist in removing/installing the parts, an old dog bed on the ground for comfort and a flashlight to see into the bottom end. Took me 3 hrs. Make sure have all the parts/gaskets available.
1977 KZ1000
1985 Gpz750
  • gaillarry
02 Oct 2007 03:20
#174106
1977 KZ1000
1985 Gpz750
  • OnkelB
  • OnkelB's Avatar
03 Oct 2007 05:58
#174324
Actually I also did a little write-up of what I did and uploaded it to the KZR filebase, here“s a link to the pdf:
650/750 four starter clutch repair
77 KZ 650 B1, 82 GPz 1100 B2.
  • KaZooCruiser
03 Oct 2007 16:07
#174419
Hey y'all, thanks for the responses so far, but I still am confused about whether I need any special tools?
Impact gun I have.
Metric sockets I have.
Rachets and breaker bars. 1/2" and 3/8".
Metric allen wrenches.
I'm going to look at my service manual again. . .maybe I just didn't read it right.
  • Jay_G
  • Jay_G's Avatar
04 Oct 2007 01:34
#174480
you will need some circlip pliers. just hit the clutch basket nut with the rattle gun, was a 30mm nut on my 750. You will also need a big good screwdriver to take the retaining plate off the bearing that the fwd shaft is supported by and the screws that hold the oil pump in place, i found i had to use screwdriver tips on my ratchet with repeated hitting with a hammer to break the seal. make sure you use loctite when re-ssembling.
