1400cc conversion
- requiem
1400cc conversion
30 Sep 2007 10:05
I'm getting my kz1000 motor converted with the 1400cc big block kit from kzzone - solumrus is doing the work
I'm looking for an oil cooler, anyone have experience with coolers on these big block motors? how does this look?
First One
or would this work out ok?
Second One
this - i like the look of...
Last Choice
any comments or hints would be appreciated. planning on throwing some more questions up here soon...
Post edited by: requiem, at: 2007/09/30 13:08
Post edited by: KZCSI, at: 2007/09/30 16:52
First One
Second One
Last Choice
- StreetfighterKz
Re: 1400cc conversion
30 Sep 2007 11:05
The oil cooler for the R1 will NOT work. Its more of a heat exchanger. As the oil passes through it just transfers the heat to the coolant so the radiator can get rid of it.
The Zx10 or Duc one will work. I'm probably gonna put a Gsxf600/750 cooler on my 1428 13.5:1 project. Things to keep in mind while looking for a cooler is mounting brackets, type of fitting, and if you go with a big enough one is where to route the tach cable.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- requiem
30 Sep 2007 11:18
anyone have a cooler on their bike? what did you use?
- requiem
30 Sep 2007 11:51Please Log in or Create an account to join the conversation.
- BohicaBob
30 Sep 2007 12:15
The oil cooler OldKawMan used is pretty good. I bought one from JC Whitney. This oil cooler reduced my Z1's oil temp an additional 30 degrees F over what the old Lockhard #700 oil cooler I had on this bike was capable of.
- StreetfighterKz
30 Sep 2007 12:17
The one on OKM will work too. If you are going to drag race it with a "professional" sanctioning body be careful with slip-on hose fittings. I'm going to stay will all threaded fittings so everything is safe and secure.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- requiem
30 Sep 2007 12:19
ok - basically what i was thinking - buy the kit from OKM and fix the little things like that, probably go with stainless braided hose... what thinketh you?
Post edited by: requiem, at: 2007/09/30 15:42
- requiem
30 Sep 2007 12:34
next question - am I going to overheat at a stoplight with 1400cc - some people tell me that even with that oil cooler, i can't ride this bike in traffic.
mark the answer -
O true O false
mark the answer -
O true O false
- themachine
30 Sep 2007 13:15
true, whats the compression?
requiem wrote:
mark the answer -
O true O false
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- requiem
30 Sep 2007 13:38
not completely sure yet - .435 cams... what's the best way to find that out?
- themachine
30 Sep 2007 13:47
did you buy a kit yet, if you buy one you should know what the compression is.
if its anything above 10.5:1 on a 1400 you won't be driving it much or not at all on the street.
- requiem
30 Sep 2007 13:47
OEM compression 1000cc Kaws is 8.7:1, 130-160 psig range, 10.25:1, 190-220 psig? I really don't know...
