inexpensive mods to a kz440
- xr350guy
- wireman
- xr350guy
header ,tweak the carbs etc,same things a 4-stroke dirtbike likes!goodluck,happy wrenching!
what exactly do you mean when you say header? Like get an aftrmarket one.....or pull the baffles?? And for carbs. I know the basics of how they work and how to adjust them, should I just get them tweaked perfect as in mixture? or are there any other mods? I know with the dirtbikes, opening up the air box, pulling baffles and tuning the carb mixture to just right helps a bit.....but is there any other mods? Also, has anyone installed an aftermarket, more agressive cam in there kz before? if so, where did you get it and for how much?
- gpzrox
obviously a dirt bike has more power than most street bikes
Bold statement -- I'm not as familiar with dirtbikes, so help me out: what dirtbike has that kind of power? Sounds like fun (actually like insanity, but I can call that fun). Of course to me, my friends 130 or so HP 400 or so pound Ducati is insane in a different way. And his is stock, well, as stock as a Ducati can be.
wireman was referring to replacing the whole exhaust: from the exhaust ports to the rear wheel area. Airboxes are pretty OK from what I have heard on street bikes. I ran individual pod filters for a week or two: the howling drove me away, but also told me how restrictive the airbox really is in factory form. But did I mention the howling?
If that is a chain model, I'd look at sprockets too.
But if you are really into the speed, any 600 or above sport bike from the 80's up will change your power ideas significantly. Find one of these KZ900's these guys are running: 1976 model, and the one I rode changed my concept of speed forever. A GSXR made me realize I could look at the road sideways at nearly triple the recommended curve speeds and still feel confident because the pegs were like 4 inches from touching. And hate it or love it, that Habusa thing is powerful. Look at Lorcans post a few days ago: his bike is uber cool, and an 84/85 to boot (well, the frame says so, doesn't it?).
Inexpensive is getting the biggest bike for your bucks. My mods for a 440 would come up to the price of an interesting bigger bike, but I would do suspension, brakes, and tires too, because HP only gets you there in a straight line, and doesn't stop you or get you around that corner.
Welcome to the forum from another newbie.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- DasTeufel
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
- xr350guy
a piped honda crf450 will put out 55 horse, and that bike weighs 219 pounds, a stock husaberg fc450 will put out 65 hp stock, and weighs about the same. Even though the ducati puts out 130 hp, it also twice the weigh. So my guess, weight to power ratio, the ducati and the husaberg are about the same. So, what size jets are you guys running then? Whats stock and how many sizes should I jump up?
- DasTeufel
As for your assumption about the Husaberg and the Ducati, not even a comparison. They were bred for very different applications, so thier power bands are very different. So please, stop comparing a dirt bike to a street bike, two different animals.
2009 KTM 690 SMC
Wildomar, CA
- wiredgeorge
- RomSpaceKnight
- Thank you received: 2
- Willo46
- xr350guy
It depends on what you plan on doing. If you are going to be running pods, go at least two sizes up on the main jet and reclip the needle to the next one down (assuming it is adjustable).
thanks fore your input, but the question was..what kind of dirtbike has that kind of power, and i was comparing the weight to power ratio, not the bike it self. Im not an idiot, I dont need you telling me that they are two totaly different bikes!
- KitNYC
- Thank you received: 1
I hate to be a wet blanket, but if performance is what you want, a KZ440 is probably not what you want to start with. A couple of other people have said something along those lines, but I'm not sure any of them has done 350 miles of I-95 on a KZ440 in one day...
The motor ain't got the oomph, & if it did, the chassis couldn't take it. The chassis can barely take what the motor does have: when I went over 75MPH on that bike, it was like hitting a "vibrate" switch, & I thought it would shake apart under me when I hit 85. (The left mirror did actually shake apart about halfway there, & something killed the motor 50 miles into the return trip.) That was on a bike with Progressive shocks; I'd hate to think what that trip would've been like on the stock shocks...
My advice would be to appreciate what you have: a great city bike that'll still smoke most any car stoplight to stoplight.
Cheers,
-Kit
