Quick Turn Throttle?
- bkitchen
28 Sep 2007 19:00
Has anyone ever modified their stock throttle to make it a little quicker? Is there a way to add some to the cam to make it pull quicker(less wrist rotation)?
- CoreyClough
- GPz550 Addiction
Re: Quick Turn Throttle?
28 Sep 2007 19:16
Motion Pro has a 1/4 turn throttle. I've seen them used on dirtbikes, but not streetbikes. :S
'85 GPz550(ZX550-A2)
28 Sep 2007 19:29
I had a quick throttle on my old BSA - 1/4 turn was WFO. It was very touchy, especially pulling away from a stop light up a steep hill, but eventually I got used to it. The biggest problem was when I would hit an unexpected pothole with the front tire - if it bounced the handlebars sometimes I'd end up with more throttle than I wanted just as the rear tire was hitting the same pothole. Personally, I wouldn't want one on a more powerful bike for normal street use. Ed
- CoreyClough
- GPz550 Addiction
28 Sep 2007 19:31
That's what I'm talking about! Drag racing only.
- bkitchen
28 Sep 2007 20:33
I'm not talking something that radical. Just a little quicker.
- donthekawguy
30 Sep 2007 19:02
I think pingelonline.com has 5/8 turn throttles.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- The Milkman
30 Sep 2007 21:24
bkitchen wrote:
It would be easier to make the pivot on the carbs smaller to get where you want to be, you want a smaller radius there. You could cut or grind the arc smaller and then mount some plates on the sides to keep the cable from slipping off. Or is it possible that piece is smaller on one of the other bike models??
It's the same as changing the gear ratio on your sprockets and chain,,, bigger front sprocket or smaller rear sprocket makes the wheel turn faster.
Post edited by: The Milkman, at: 2007/10/01 00:27
Post edited by: The Milkman, at: 2007/10/01 00:28
- bkitchen
01 Oct 2007 05:52
Thats more what I am looking for Milkman. I googled it and saw someone had done it on a newer R1 and was wondering if somebody had done it to these bikes. They worked from the throttle side actually by making the radius of where the cables went around bigger. They made an insert out of PVC I believe.
