Will KZ100 header fit Z900
  • GregZ
  • GregZ's Avatar Topic Author
26 Sep 2007 18:27
#173060
Will a kerker 4 into 1 header that is currently on a kz1000 fit on my 75 Z900
thanks
  • bob_z1
  • bob_z1's Avatar
Re: Will KZ100 header fit Z900
26 Sep 2007 19:12
#173075
It will bolt to the cylinder head just fine... you may need to make/alter the mount at the rear depending which KZ1000 it's from.
  • patmann
  • patmann's Avatar
27 Sep 2007 06:15
#173151
Bob is 100% correct. Every Kerker I've ever had, I had to make a small bracket for. The problem,if you want to call it that, is the rear attaching point. The 1000 headers "can" sticks out maybe 1" more than a 900's. The 'problem" is not the "can" from what I've seen, it's the pipe it's self.
The Kerker that was on my Z1 when I got it had a 5" bolt that was bent and washered to hold it on
:blink: :S :pinch: . It took me about two minutes to fab a much better bracket. Once I was happy with the fit, I spray painted it black;)
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
