- Thank you received: 88
Clutch adjustment - How to ??
- GregZ
25 Sep 2007 17:06 #172841
by GregZ
Clutch adjustment - How to ?? was created by GregZ
Can someone please tell me the correct way to adjust clutch cable on 75 z900. What is the setting on the clutch release mechanism
thanks gregz
thanks gregz
- Thank you received: 2098
25 Sep 2007 19:31 #172860
by Patton
Replied by Patton on topic Clutch adjustment - How to ??
Here's a link for you.
click here
Clutch pushrod adjustment on 75KZ900 is 1/2 turn counter-clockwise from lightly seated position.
click here
- GregZ
25 Sep 2007 19:35 #172861
by GregZ
Replied by GregZ on topic Clutch adjustment - How to ??
Thanks
- trianglelaguna
- Thank you received: 235
01 Jan 2009 15:13 - 01 Jan 2009 15:22 #255702
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Clutch adjustment - How to ??
i had my clutch acting grabby the last 1/4 on letting it out from a dead stop yesterday...not while moving and shifting.just from a stop..so i lubed the cable some and adjusted the pushrod a half turn back and tightened the nut a few minutes ago... and went for a short ride and it still engages jerky the last bit of lever out.. from a stop...i think i might have to lube the plastic actuater inside the sprockett cover..i soaked the sprockett cover and stripped the shitty paint off it the last guy put on and polished it up ... then i put it back together and did not put grease on the corkscrew nylon peice that the cable pulls on...think this is my prob.. i hope....grease and re-assemble...here goes...
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 01 Jan 2009 15:22 by trianglelaguna.
- trianglelaguna
01 Jan 2009 19:33 #255724
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
cleaned the push rod..had some thick gunk next to sprockett...found a screw had fallen out of the two screws that reatain the worm drive housing...lubed rod...lubed worm drive..replaced screw..readjusted lock nut and cable....sweet shifting.....simple fix..i'm a veg....missed the first time....
1976 KZ900
2003 ZX12R
2007 FZ1000
- dman3998
01 Jan 2009 21:00 #255731
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Replied by dman3998 on topic Clutch adjustment - How to ??
wished someone had mentioned Oh ya, not a good plan to take apart the worm drive clutch deal. them ball bearings in there are REALLY little.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
