78 kz650 B valve questions
  • Kingcobra
  • Kingcobra's Avatar Topic Author
25 Sep 2007 15:35
#172825
I'm thinking the valves need adjustment. I have a flutter when revving (idle is fine) and I blew the carbs out and its still there. could be a plug but I don't think it is and the bike has around 11,000 miles on it and I have no idea if its ever been done. I'm going to adjust them myself butI don't have a manual so if anyone can help me out I'd appreciate it. thanks.
  • Kingcobra
Re: 78 kz650 B valve questions
25 Sep 2007 17:58
#172844
ok replaced the plugs... idle is still fine... but I feel the flutter from time to time when riding. and it acts like its loading up on hard acceleration. so it may be carb related. I still need to know if these valves need adjusting tho. any help?
  • mariozappa
  • mariozappa's Avatar
26 Sep 2007 07:08
#172924
Valve Clearance (cold) 0.003 - 0.007 in.(0.08-0.18mm)
kz650files.kz650.info/adobe/650ValveLash.pdf
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Kingcobra
28 Sep 2007 17:10
#173376
I think the problem was a loose sync tube cap... we'll find out tomorrow.
