OIL COOLERS
  • outatimeoutlaw
  • outatimeoutlaw's Avatar Topic Author
OIL COOLERS
22 Sep 2007 13:28
#172205
Does anyone know a source for a kit for the KZs ??
OLDKAWAMAN has a good description of how to fab it up yourself, but I wanted to check out sources before I do all that work. ANY help would - well - help
TANX GUYS
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: OIL COOLERS
23 Sep 2007 07:32
#172332
Some people on here use the coolers available through JC Whitney, other use coolers made for the older oil-cooled GSXR or any 600/750 Katana. You need to figure out how big a cooler you need and start searching eBay. Even some ATV's have decent sized coolers that would work.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Bluemeanie
  • Bluemeanie's Avatar
Re: OIL COOLERS
23 Sep 2007 07:54
#172336
Don't know what KZ you have but have heard here that I believe GPZ550/750 (?) oil pans with coolers are a bolt on job!! Have to fab the cooler to frame but pan bolts right on!!
  • tjettim
  • tjettim's Avatar
Re: OIL COOLERS
24 Sep 2007 03:39
#172469
Once in a while you can srill find new
Lockharts for KZ750s.On ebay there are some
used ones floating around.
  • kenskz1000
  • kenskz1000's Avatar
Re: OIL COOLERS
24 Oct 2007 22:42
#178018
I bought a oil cooler from JC Whitney, works great but now I can't use a steering damper which I really need.
  • jeffo
  • jeffo's Avatar
Re: OIL COOLERS
24 Oct 2007 23:40
#178023
I did just that! I got a oil pan an cooler from GPZ and it was a straight bolt on. The only thing I had to do was fabricate a mounting bracket since I got it without one.
I got it by doing a parts inquiry through www.uneedapart.com/used-kawasaki-motorcycle-parts.php I got more then one response and once I got the price I wanted I bought it :P
1981 KZ650H1 CSR
  • racer54
  • racer54's Avatar
Re: OIL COOLERS
25 Oct 2007 01:02
#178031
I believe OLDKAWMAN will sell you a kit that comes with everything you need or it's ready to go, can't remember which but I remember reading that while I was on his site awhile back.
  • z1rick
  • z1rick's Avatar
Re: OIL COOLERS
26 Oct 2007 22:10
#178317
Check this out:
www.oldkawman.com/
Half way down on left, oil cooler fabrication link.
Post edited by: z1rick, at: 2007/10/27 01:12
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
  • The Fish
  • The Fish's Avatar
Re: OIL COOLERS
27 Oct 2007 06:13
#178326
z1rick wrote:
Check this out:
www.oldkawman.com/
Half way down on left, oil cooler fabrication link.<br><br>Post edited by: z1rick, at: 2007/10/27 01:12
MAN!! Look at all the RTV silicon sealer on that motor!:S I would imagine that there is equal amounts of sealer on the inside of the engine gaskets also.
WOW!
Fish
Re: OIL COOLERS
27 Oct 2007 06:39
#178327
The Fish wrote:
z1rick wrote:
Check this out:
www.oldkawman.com/
WOW!
Fish
Yuk!
  • z1rick
  • z1rick's Avatar
Re: OIL COOLERS
27 Oct 2007 13:27
#178380
Probably won't leak oil :P
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
  • 76 LTD
  • 76 LTD's Avatar
Re: OIL COOLERS
29 Oct 2007 18:00
#178723
I believe Z1 enterprises and/or american classix has the block fittings(they aint cheap)then all you need is a cooler.
