Sprocket Cover O-Rings?
  • ace4mestl
  • ace4mestl's Avatar Topic Author
16 Sep 2007 18:26
#170998
I have an issue with o-rings. I removed the sprocket cover on my 1980 kz1000 LTD. and I undid the clutch adjuster cover (that cover with the 2 allens theres a seal in there). I ended up with 3 broken o-rings, along with years of dirt. One I know came off that pushrod inside when I pulled it out.(goes from the clutch release mechanism through the tranny) The other 2 I have no idea. They could have fell off from the adjuster cover but i didn't see them. I cant find anything in my book either. Except for the one that was on the pushrod. There are just 4 bolt holding that sprocket cover on and I didnt see anything that those
o-rings would fit. Any help would be appreciated. Jeremy
  • ace4mestl
Re: Sprocket Cover O-Rings?
16 Sep 2007 23:01
#171031
Well I found another one and a partial in the gunk below the sprocket (Very dirty inside cover o-rings could have been there for awhile). My bike doesn't have the sprocket guard. (Guard goes right over the sprocket)I can only think that they came from that cover thats not there, or an old chain. Since there's 3 now it can't be the adjustment cover. If you know if there's more than 1 o-ring in here let me know. Like I posted the only one in the book is on the pushrod. I have not removed the sprocket. So it's just in this area.
  • Samwell
  • Samwell's Avatar
17 Sep 2007 03:10
#171037
Are these rubber o-rings, larger oil seals, or kind of doughnut shaped coiled springs? The reason I ask is, my machine doesn't have o-rings per se at the adjustment cover. I don't have a sprocket guard either - apparently only some models had this. I do, however, have oil seals, and part of these oil seals are these little coiled springs and they can come out of the seal. Check kawasaki.com for parts diagrams and it'll show what you need.
Sam
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
17 Sep 2007 03:31
#171041
Sounds like your O-ring chain may be getting old and shedding O-rings.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • donthekawguy
  • donthekawguy's Avatar
17 Sep 2007 03:56
#171048
I have never heard of any o-rings for the cover. Like was already said, probably just o-rings coming off the chain. Take a real close look at your chain, link by link and you should see some of the o0rings coming apart.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • ace4mestl
17 Sep 2007 09:44
#171110
Sam
These are small round rubber(same size as the pushrod one). The one came off the pushrod coming from the clutch adjuster assembly. Thats what I'm thinking they are off the chain. What is strange though is they aren't destroyed just split on one side and intact.
  • Skyman
  • Skyman's Avatar
17 Sep 2007 10:07
#171113
I'm also thinking chain rings. Same thing happened to me. When my o-ring chain went bad, I started finding broken o-rings piling up in the goo inside the sprocket cover. Examine your chain closely. I'll bet you'll find several missing o-rings.
West Linn, OR
  • ace4mestl
17 Sep 2007 10:31
#171116
Thank You very much. Jeremy
