- Thank you received: 1
Stripped threads
- 76 LTD
16 Sep 2007 17:46 #170992
by 76 LTD
Stripped threads was created by 76 LTD
Ok i was checking everything over before firing uo my 79 1000 that has been sitting for a few years and discovered that 2 of the bolt holes for the cam bearing caps are stripped can you get Heli coils in this size? or do i need to just drill and tap to next larger size.that might be a problem as the bad holes are the ones for the dowell pins Thanks
- Samwell
17 Sep 2007 02:03 #171034
by Samwell
Replied by Samwell on topic Stripped threads
76 LTD wrote:
Helicoils are available in almost every size. The cam bolts aren't an odd size(at least as far as know). You might want to look at these: www.timesert.com .
AS there a little more robust than helicoils.
Hope this helps...Sam
- 76 LTD
17 Sep 2007 18:56 #171217
by 76 LTD
Replied by 76 LTD on topic Stripped threads
Ok thanks i will check them out.
- coppertales
18 Sep 2007 12:51 #171361
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Stripped threads
Just about every auto parts store has the kits to install helicoils in the stripped out holes. I have done two complete heads because the ham handed former owners don't know the difference between inch lbs and foot lbs or what a torque wrench even is. I picked up an extra length drill bit so I could drill out the old threads without removing the head. I got it at either Home Depot or Lowe's.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
