Will a 83-84 1100 head fit on a 81-82 1100
  • otakar
  • otakar's Avatar Topic Author
14 Sep 2007 10:55
#170547
Hi All
Will a 1983/84 GPZ Head fit on a 1981/82 J motor?
The heads look to be the same casting, only the combustion chamber looks different. has anyone tryed this?
Otto Kudrna
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • racer54
  • racer54's Avatar
Re: Will a 83-84 1100 head fit on a 81-82 1100
14 Sep 2007 11:31
#170551
It should fit, but the head you are talking about ('83-'84 GPZ) has a different shape combustion chamber. I believe it takes a different piston so you might have to use different pistons to fit that particular head. SO....head should fit, but the motor will probably need other modifications to work right.
  • jcote75
  • jcote75's Avatar
14 Sep 2007 11:38
#170554
Hi,
I can trade your head with mine. I got a kz1000j head. It was in an 81 so fuel injectors on the head. Got only the head with cam caps.
Joce
  • otakar
14 Sep 2007 11:54
#170557
That is what I noticed, That the 83/84 head has try-shyrical combustion chambers. Being set deeper in the head, this would mean that the compression would be a bit lower. This would be no problem, only to measure the chamber volume and do the math. as long as it would bolt on and mechanicly function with the same cam drive, is what I was conserned about.
Otto Kudrna
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • steell
  • steell's Avatar
14 Sep 2007 19:23
#170652
The 83-84 1100 head is generally considered to be the best two valve head Kawasaki ever made, and it usually sells for $600-$800 on eBay.
