Piston replacement
  • federal officer
  • federal officer's Avatar Topic Author
Piston replacement
14 Sep 2007 06:41
#170508
Hi all, easy question i hope!!! i'm replacing the head on my 1979 kz-750B twin because its cracked. Will i be able to remove the cylinder at that point and replace the pistons while still in the frame??? I figured while its that far down i can buy a set brand new for $25.
thanks in advance.
  • steell
  • steell's Avatar
Re: Piston replacement
14 Sep 2007 07:08
#170516
Yes, you can remove the cylinder and replace the pistons without removing the motor from the frame.
Be sure and have the cylinder checked for wear before spending the money for new standard pistons.
  • federal officer
14 Sep 2007 10:47
#170544
Thanks steell.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
14 Sep 2007 12:46
#170566
I've always found it easier in the frame. I've heard that some people have even kept the original base gasket and cylinders in place when changing the head. I would probably pull it and replace the gasket just to be sure though. Might as well bore it one size up and get some new pistons. Might as well port the head and go with a little bigger cams too while you're in there. As long as money is no object, that is!:P
Post edited by: 79MKII, at: 2007/09/14 15:47
The Kaw List:
  • federal officer
14 Sep 2007 13:08
#170569
LOL if money were no object then i would not be playing with a 1979 kz-750 , no offence to anyone !!!!
  • BSKZ650
  • BSKZ650's Avatar
14 Sep 2007 13:27
#170571
I am guessing you have new pistons and rings in your hand, if not ...........
1 if and I say if, they are going to be expensive, I got a set off flebay, and they were not cheap.
2 you are not going to find any aftermarket stuff either, I talked to jeff about it and he didnt have a line on them at the time
77 ltd1000, current rider
76 kz900, just waiting
  • steell
  • steell's Avatar
14 Sep 2007 17:30
#170619
LoudFastandUgly has all standard and oversize piston kits for the KZ750 twin listed at $45 each.
You can send your cams in and get them reground at Web Cam (I think) for $280.00, but that's about it for aftermarket hot rod parts for the 750 twin.
  • The Milkman
  • The Milkman's Avatar
14 Sep 2007 18:03
#170629
Thanks for that link steell, I never knew they existed.
Ride safe
  • 1045
  • 1045's Avatar
14 Sep 2007 19:04
#170647
Is there something wrong with the pistons that are in there now???? does the bike burn oil or have alot of miles on it???? If not, why replace them????
1045
1045
  • federal officer
15 Sep 2007 09:07
#170716
I found a set on ebay,a new set,for 24$$ which i think is a good price. does burn oil and the motor has 45,000
miles on it. i guess i dont need to but having the motor torn down that far and being the pistons are so cheap i figures why not !!!
  • 1045
  • 1045's Avatar
15 Sep 2007 10:59
#170731
Way to go then, if you not boring to oversize, make sure you hone the barrels good so the new rings will seat.....hopefully
1045
1045
