Should I be able to hear the cam chain?
- seanof30306
10 Sep 2007 05:10
'79 KZ650
Just after I bought the bike, I started hearing the cam chain making noise. It would come and go; sometimes getting so bad the bike would "catch" at idle and nearly shut off.
Took it to a shop. He said the automatic cam chain tensioner was frozen up, and he'd fixed it.
I still hear the cam chain, although not as bad as before. I hear a slight "ringing" sound from it all the time, and occasionally it gets worse, tohough, again, not as bad as before. Is this normal?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- baldy110
- ltdrider
Re: Should I be able to hear the cam chain?
10 Sep 2007 07:38
Baldy's right. But you may not be hearing your cam chain. Don't know what would cause a 'ringing' sound... maybe something like a header pipe vibrating and touching the frame?
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- Grantl
- KZRider is Da Bomb!!!
10 Sep 2007 09:55
Maybe what you are hearing is the cam chain rubbing on a metal part of the tensioner. It could be that the phenolic part of the stuck tensioner became worn down to the metal. You may not always hear the noise because the tensioner is free--the cam chain rides for the most part on the phenolic. But under accelleration or decelleration the load on the chain changes altering the angle of contact on the tensioner which then allows the chain to contact the exposed metal portion on the tensioner. Could also be that the phenolic block that is mounted in the roof of the cam chain cover has come loose or is worn through and the ringing noise is the cam chain running against the cover.
Just my 2 cents worth.
Grant.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- seanof30306
10 Sep 2007 12:57
ltdrider wrote:
"Ringing" is just my attempt to describe what I'm hearing; it's definitely the cam chain.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- seanof30306
10 Sep 2007 13:04
Grantl wrote:
That sounds pretty reasonable. Question is; how problematic (or potentially problematic) is it?
Grant.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- KZQ
- Administrator
10 Sep 2007 17:55
If Grant's right you got troubles. Some wear on the tensioners is tolerable but if you've worn through to the metal bits you're outta tolerance.
On the lighter side cam chains tend to the canary of the KZ world. If your chain's a bit loose any thing that upsets the rhythm of the engine will cause a cam chain slap. This includes poor carb mixture, poor ignition, all down the line, you name the problem if it causes the engine to stumble, the cam chain will complain.
Keep us posted.
KZCSI
Keep us posted.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
