valve cover bolts
- hardr0ck68
- Who put the what in the where?
valve cover bolts
07 Sep 2007 08:13
on a 77 650 are all the valve cover bolts the same length? I have 4 longer bolts laying around that look exactly like the valve cover bolts only they are an inch longer.
It has been a long time since i have put a valve cover on....this is a happy day for me
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Bluemeanie
Re: valve cover bolts
07 Sep 2007 08:32
I believe the 4 longer bolts will go in the ends of the valve cover. This is the 4 points where the rubber 1/2 circle seals are.
07 Sep 2007 09:47
Mine are all 6mm x 45mm. Ed
- OKC_Kent
07 Sep 2007 12:45
The diagram on buykawasaki for the 77 c-1 shows two valve cover assemblies, one of them has the reed valves. Do you have those? If so they have 4 65mm bolts and 4 22mm bolts to fasten them.
Check your engine side covers too, maybe you had one off for some reason?
Post edited by: OKC_Kent, at: 2007/09/07 16:06
Cashion, OK
78 KZ650 B2 85,000+ miles
- RonKZ650
07 Sep 2007 13:15
On a 77 they are all the same. Reed valves were not used until 1979.
- reborn650
07 Sep 2007 14:41
I have the allen head, stainless bolt set for my engine and all of the valve cover bolts are the same length and pitch.
These aftermarket bolt sets are very good in my opinion as they are easy to remove, tough to strip the head and they look pretty trick. I think that Z1 Enterprises offers them for the complete engine but if not, they can be found on ebay. Just check to make sure you are getting the full set including the long bolts for the cases.
Remember to put a little dab of anti-seize on the threads as this will save you some hassle years down the road.
-1998 Jeep TJ Wrangler 4.0...
- hardr0ck68
07 Sep 2007 16:08
Ok well i do not have the smog reed valves, so i do not know where these longer bolts came from.
I thought the hex head with #3 philips slots were only used on the valve covers. So i was wondering where the 4 longer ones like that go.
I am sure i will figure it all out when eventually.
1977 kz650 c1
