cold plugs
- themachine
cold plugs
06 Sep 2007 03:21
i'm currently running ngk b10es plugs, up from the stock b8es's, higher the number the colder the plug.
problem is that the local idiots cant find them any colder than 10 and they are glowing red hot under mild acceleration when warm.
doe anyone know of a plug colder than 10?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- BSKZ650
Re: cold plugs
06 Sep 2007 05:14
the lower the number the colder the pulg, you are running 2 up hotter plugs, may be causing some preignition
77 ltd1000, current rider
76 kz900, just waiting
- brianrae33
Re: cold plugs
06 Sep 2007 05:36
on ngk's the higher the number the colder the plug..might be different on other brands but ngk's run higher the colder..
1982 kz1000ltd
- mark1122
- Keep twisting it
Re: cold plugs
06 Sep 2007 05:58
if your plugs are glowing red hot i would first ask, WHY?Please be carfull running it like that.how do u know they are red hot?
i see u have new carbs.
are u jetted right,is timing right?
Something sounds off.
have u tried to richen the mix? this will help to cool the cyl.also retarding the timing.
Post edited by: mark1122, at: 2007/09/06 09:01
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BSKZ650
Re: cold plugs
06 Sep 2007 06:05
your right, wrong plug mfg, had it in my head from the race car plugs, got to run cold ones for the high constant high rpm
Re: cold plugs
06 Sep 2007 11:23
mark1122 wrote:
Concur with above by mark1122.
Per FSM, plug heat range should not go more than one step in either direction.
Motors usually don't overheat for no reason.
Any ideas why this is happening?
Some possible reasons for overheating are:
Engine performance modifications
Defective oil pump or screen clogged
Oil level too low or too high
Spark plugs bad or maladjusted or wrong heat range
Ignition timing maladjusted
Float bowl fuel level too low
Main jet clogged
Carb holders loose or cracked, loose carb clamp
Air cleaner poorly sealed or missing, or duct leaking
Clutch slipping
Brakes dragging
Compression excessive from carbon build-up
Good Luck toward resolving the overheating problem.
have u tried to richen the mix? this will help to cool the cyl.also retarding the timing.<br><br>Post edited by: mark1122, at: 2007/09/06 09:01
Main jet clogged
Clutch slipping
Brakes dragging
- themachine
Re: cold plugs
06 Sep 2007 18:03
i have performance modifications, see siggy.
good oil pressure
full on oil
i'v been playing with the ignition seeing if it will run cooler
i am having issues with the jets, exhaust popping on decel
fresh carb holders and pods.
and 178psi on a 1400 mile 1170cc rated at 10.25:1
i had speed glazing on the stock plugs, its a yellowish tint with no resedue on the tips.
under acceleration when hot it misses, gets worse with lower octane and the hotter plugs.
good oil pressure
full on oil
- BSKZ650
Re: cold plugs
07 Sep 2007 05:02
from what you saw on the plugs, it sounds lean, what happens if you add just a bit of choke to it to fatten it up
- mark1122
- Keep twisting it
Re: cold plugs
07 Sep 2007 05:41
i agree with ksk650.it sounds lean. if u reinstall your baffle it will richen slightly as well. ar u running bs or rs 34's? what jets are in them? pilot,pilot air screw setting, needle clip position, and mains ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- themachine
Re: cold plugs
07 Sep 2007 15:15
wiredgeorge awnsered my carburation question in another thread, thanks.
Re: cold plugs
07 Sep 2007 15:26
themachine wrote:
Question please to confirm ---
Are the metal casings of all four plugs glowing red hot where they screw into the head?
Reason for asking -- While some problems affect all cylinders (such as ignition timing or compression), other issues such as intake air leak, clogged jetting, or low float bowl fuel level, sometimes plague only one cylinder.
Could be excessive compression.
What are psi readings on compression test?
Should use strobe type timing light to assure ignition being spot-on, and also that the advancer unit is working.
If these carbs have rubber vacuum nipple caps, maybe they are leaking and allowing air intrusion.
Would also assure correct float bowl service fuel level. Hopefully, the quick easy clear plastic tube method may be used to check the levels.
Wishing you success!
... they are glowing red hot under mild acceleration when warm....
- mark1122
- Keep twisting it
Re: cold plugs
07 Sep 2007 20:29
themachine wrote:
what was the q and a ?wiredgeorge awnsered my carburation question in another thread, thanks.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
